TVHeadEnd EPG dashboard
Apart from using the Node-RED dashboard for controlling hardware devices, I have now also added a tab that allows for the following:
  • Search the TVHeadEnd EPG based on (optional) channel and program title
  • Add a single recording
  • Add a series recording
  • Delete a single recording
The flow can be found here: https://flows.nodered.org/flow/1cb5eced9e4f22bb2be1e86e33dbb25a
Please let me know if you think this is useful, or have any suggestions for improvements.
Hi rsenden,
thank you very much for sharing this with us.
My personal goal is to achieve a personal timeshift with TvHeadend.
Means in short:
I want to select few channels and those channels should be "AutoREC" for at least 24 hours. I should be able to select on EPG to rewind the passed programmes.
e.g. BBC News
BBC should be recorded for 24 hours. I should be able to select at 22:00 pm from the EPG the programm at 18:00pm and should be able to watch.
In your project I can select it eachwise. Would be great if I can say channel xyz record for 24 hours.
Thanks in advance for your reply.
