Hi everyone,
Feedback is welcome on this!
I found a way to Tweet using the Twitter API v2 leveraging on node-twitter-api-v2 module using a free tier app (Tweets - post up to 1500 Tweets per month)
1. App Setup on Twitter
Ensure you have set up your Twitter App correctly in the https://developer.twitter.com/en/portal/apps
You need to attach the app to a project. You need also the following credentials:
- appKey: 'API Key',
- appSecret: ' API Key Secret',
- accessToken: 'Access token',
- accessSecret: 'Access Token secret'
2. Twitter-api-v2 module import in node-red
Import the module in node-red: twitter-api-v2 in the setup tab by adding twitter-api-v2 with the + - this creates a module called twitterApiV2
3. Usage
Use the lib as twitterApiV2 in your code :
const Twitter = twitterApiV2.default;
4. Sample flow (please change the credentials, or find a better secured way to send them to the API):
    "id": "662907decf527b93",
    "type": "function",
    "z": "a9336bf7.8341c8",
    "name": "Tweet with twitterApiV2",
    "func": "const Twitter = twitterApiV2.default;\n\nconst client = new Twitter({\n  appKey: 'API Key',\n  appSecret: '  API Key Secret',\n  accessToken: 'Access token',\n  accessSecret: 'Access Token secret',\n});\nvar image_url = msg.url;\n\nvar tweet=msg.payload; //text coming from my payload\nvar buffer=msg.media //image buffer stored before in msg.media - call image url with http get node to get the buffer\n\n    // First, post all your images to Twitter\n    const mediaIds = await Promise.all([\n      \n      // using local file path\n      //client.v1.uploadMedia(image_url),\n      \n      // using image as a buffer\n      client.v1.uploadMedia(buffer, { type: 'png' }),\n\n    ]);\n\n// Wrap the tweet posting logic inside an async function\n(async () => {\n  try {\n    const result = await client.v2.tweet({\n      text: tweet,\n      media: { media_ids: mediaIds }\n    });\n    msg.tweet_text = \"You successfully tweeted: \" + result.data.text;\n    msg.result = result;\n    node.send(msg);\n  } catch (err) {\n    msg.payload = \"Error: \" + JSON.stringify(err);\n    node.send(msg);\n  }\n})();\n\nreturn null;",
    "outputs": 1,
    "noerr": 0,
    "initialize": "",
    "finalize": "",
    "libs": [
        "var": "twitterApiV2",
        "module": "twitter-api-v2"
    "x": 3370,
    "y": 800,
        "6a940578382929af",
        "259d43ee8773b6e1"
    "id": "bad44f1879819e79",
    "type": "inject",
    "props": [
        "p": "payload"
        "p": "topic",
        "vt": "str"
    "repeat": "",
    "crontab": "",
    "once": false,
    "onceDelay": 0.1,
    "topic": "",
    "payload": "",
    "payloadType": "date",
    "x": 3200,
    "y": 620,
        "662907decf527b93"
    "id": "6a940578382929af",
    "type": "debug",
    "name": "debug 6",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "complete": "true",
    "targetType": "full",
    "statusVal": "",
    "statusType": "auto",
    "x": 3640,
    "y": 740,
    "id": "259d43ee8773b6e1",
    "type": "debug",
    "name": "debug 7",
    "active": true,
    "tosidebar": true,
    "console": false,
    "tostatus": false,
    "complete": "tweet",
    "targetType": "msg",
    "statusVal": "",
    "x": 3640,
    "y": 860,
