FloRu
                    5 March 2024 22:14
              1
              Continuing the discussion from Force disconnection of TCP connection :
Today I tried to disconnect the newly connected TCP request node (using 2 connections, one on port 1111 and the second to the same server, port 1112) and continue getting this error...
I tried both of these disconnect messages
(only one each time), but always get this error message - what am I doing wrong?
Florian
              As a test, please try adding payload to the message (and set it as an empty string).
                FloRu
                    5 March 2024 23:39
              3
              Hi Steve,
no, it only accepts the message like this without an error message:
...but doesn't change anything in the configuration > messages keep running in...
                FloRu
                    5 March 2024 23:45
              4
              And it also doesn't change if I insert host / port into the request node...
                system
                  Closed
                    3 June 2024 23:46
              5
