Good evening,
has anyone had the need to extend an already included package with an additional plugin?
As an example, I'd like to use a plugin (utc.js) from the dayjs library.
In plain JavaScript would be easy to extend, see: UTC · Day.js
Is there a way to accomplish this in ui builder?
Code so far:
index.html
<script src="../uibuilder/vendor/dayjs/dayjs.min.js"></script>
<script src="../uibuilder/vendor/dayjs/plugin/utc.js"></script>
<script src="./uibuilderfe.min.js"></script> <!-- //prod version -->
<script src="./index.js"></script>
</body>
</html>
index.js:
var app1 = new Vue({
el: '#app',
data: {
periodParams: {
startDate : dayjs().startOf('day').subtract(1, 'month').toDate(), // works fine
endDate : dayjs().utc().startOf('day').toDate() // fails to load ui builder page
The definition of endDate using the utc() function will lead to an
Uncaught TypeError with the browser complaining dayjs(...).utc is not a function.
Anyone having a tip how to get this plugin integrated?
Cheers,
Marcel
Hi Marcel ..
have you tried dayjs.extend(utc) as described in the link you sent ?
either in Vue's created or mounted Lifecycle Hooks
or even outside the Vue app1 code .. before Vue is created.
[EDIT]
ok .. i tested this and what worked for me was to use
dayjs.extend(window.dayjs_plugin_utc) // load utc plugin
outside the Vue app code
source
Yes mate, I've tried that.
Problem is, that it does not know 'utc'
in index.js:
created: function() {
var utc = require('dayjs/plugin/utc') // or whatever path to utc..
dayjs.extend(utc)
ReferenceError: require is not defined
at wn.created (index.js:719)
at He (vue.min.js:6)
at Yt (vue.min.js:6)
at wn.t._init (vue.min.js:6)
at new wn (vue.min.js:6)
at index.js:203`Preformatted text`
When I declare utc outside the Vue app like this...
dayjs.extend(utc)
... it's not knowing require.
Regarding your edit. What is 'dayjs_plugin_utc' referring to?
Hi, this page has the answer: Loading plugin in the browser · Day.js.
You cannot use require or import in the browser unless you have a build step that converts it (or, for import, your library is a HTML module in a newish browser).
facepalm
How could I miss this page in the same menu tree!
Now that it's working the timestamps sent to NR no longer carry that stupid local timezone.
Again, you have my big Thanks! @TotallyInformation
