Radio Group
There is an option in the config to set the number of columns. It accept values 1 to 5 I have, let's say, 6 options to display. The widget width is "auto".In a relatively narrow group I can set it to 3 columns: -- Width 4
If the group is set wider the options spread out -- Width 8
-- Width 24 (Sorry the forum does not show the difference unless you zoom in)
There is clearly space for many more columns in a wider group yet however wide it is, you can only set a maximum of 5 columns.
** 1 Why the restriction?**
Button Group
If the width of the button group is constrained, either by group width or widget width -- here 4, the options are just truncated.You can't even rely on fitting 3 buttons in the available space because long button labels are displayed on one line, so the cut-off point changes
2 Shouldn't the width of individual buttons be set so that all of the defined options will fit in the available space, and button labels word wrap if necessary? cf Radio group
Both
3 The labels of these two widgets are positioned differently.
4 The options for radio group and button group are not consistent.
Radio Group: Value, Label
Button Group: Label, Value
