Ui-chart / eCharts: valueFormatter or formatter? But how?
Hello guys,
in my current little hobby project I'm (amongst other astronomical things) visualising the day length for certain locations. Here's how the chart currently looks like:
Now I want the daylight hours – a decimal number that comes from my API – in the tooltip to be displayed in an hh:mm:ss format instead of the pure floating point number.
Here's the function node's code that sits directly in front of the chart node (sorry for the German comments :man_shrugging:):
const apiResponses = msg.payload;
const flatPayload = [];
apiResponses.forEach(response => {
    response.curve_data.forEach(pt => {
        // Präzise Umrechnung in Sekunden für hh:mm:ss
        const totalSeconds = Math.round(pt.daylight_hours * 3600);
        const h = Math.floor(totalSeconds / 3600);
        const m = Math.floor((totalSeconds % 3600) / 60);
        const s = totalSeconds % 60;
        // Formatierung nach ISO (24h)
        const timeStr = [h, m, s]
            .map(v => v.toString().padStart(2, '0'))
            .join(':');
        flatPayload.push({
            series: response.location,
            x: new Date(pt.date + "T12:00:00Z").getTime(),
            y: pt.daylight_hours,
            // Wir parken den Zeit-String im 'name' Attribut für den Tooltip {b}
msg.payload = flatPayload;
msg.ui_update = {
    chartOptions: {
        tooltip: {
            show: true,
            trigger: 'axis',
            formatter: '< now what here??? >',
            valueFormatter: '< or is it this one? how? >'
// Ausgang 1: Chart | Ausgang 2: Spinner-Template (auf false setzen)
return [msg, { payload: false }];
So, you see, I already did the building of the string I want to see but I just don't know how to put it into the value region of the tooltip window. :disappointed_face:
The 2nd output of the function node just triggers the visibility of a spinner so that during the HTTP requests that actually get the data from the API the user sees that something is happening.
Here's a screenshot of a debug node's output that shows the data right after the function node:
We see that the duration formatting (key name) actually works.
But how can I replace the decimal duration in the tooltip with this string now?
In case it's important: The chart node is configured like this:
Thanks so much in advance!! :folded_hands:
Stefan.
Unfortunately, in order to do that, you would need to use tooltip.valueFormatter, I think, passing it a callback function to perform the formatting that you want. That doesn't work in chartOptions, but I don't know whether the problem is that the code in the ui-chart widget does not work with callback functions, or if there is a problem with valueFormatter, or possibly a combination of the two.
At the moment I don't know of a solution.
Thanks, @Colin, for this response. Makes me slightly happy because now I know that it doesn't seem to be easy.
Maybe a template node can be of help here where we access the echarts DOM object and can pass/add/inject a callback function somehow? :face_with_monocle:
