I have a multi-line chart based on the example in Dashboard 2 documentation for ui-chart under working with data " Alternatively, you can set the series property to type JSON , and then provide an array of keys (e.g. ["key1", "key2"] ), which will plot a data point for each key provided, from a single data point.".
Following the example, if the series property is set to ["value","nested.value"], both lines are plotted correctly.
If I try to simplify the chart by setting the series property to ["value"], the data is not rendered for the remaining key.
If, however, I set the series property to ["value",""], i.e. providing a bogus empty key, the "value" data are plotted correctly,
sample flow showing the case with the bogus key and the case with only one key.
"id": "5141797ff72d0139",
"type": "tab",
"label": "Flow 3",
"disabled": false,
"info": "",
"env": []
"id": "34f54f48465ae005",
"type": "inject",
"z": "5141797ff72d0139",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": true,
"onceDelay": 0.1,
"topic": "",
"payload": "[{\"x_value\":12,\"value\":17,\"nested\":{\"value\":24}},{\"x_value\":17,\"value\":36,\"nested\":{\"value\":10}},{\"x_value\":23,\"value\":19,\"nested\":{\"value\":75}},{\"x_value\":34,\"value\":12,\"nested\":{\"value\":23}}]",
"payloadType": "json",
"x": 156.4545440673828,
"y": 149.48723220214845,
"65e8d05f0bc013dc",
"2ae6bb0373297074"
"id": "65e8d05f0bc013dc",
"type": "ui-chart",
"group": "2e3b032902dae011",
"name": "chart with bogus second key",
"label": "chart",
"order": 9007199254740991,
"chartType": "line",
"category": "[\"value\",\"\"]",
"categoryType": "json",
"xAxisProperty": "x_value",
"xAxisPropertyType": "msg",
"xAxisType": "linear",
"yAxisProperty": "",
"ymin": "",
"ymax": "",
"action": "replace",
"pointShape": "circle",
"pointRadius": 4,
"showLegend": true,
"removeOlder": 1,
"removeOlderUnit": "3600",
"removeOlderPoints": "",
"colors": [
"#1f77b4",
"#aec7e8",
"#ff7f0e",
"#2ca02c",
"#98df8a",
"#d62728",
"#ff9896",
"#9467bd",
"#c5b0d5"
"width": 6,
"height": 8,
"className": "",
"x": 372.4601860046387,
"y": 149.56396293640137,
"id": "2ae6bb0373297074",
"type": "ui-chart",
"name": "chart with single key",
"label": "chart",
"category": "[\"value\"]",
"ymin": "",
"ymax": "",
"pointRadius": 4,
"showLegend": true,
"removeOlder": 1,
"colors": [
"#1f77b4",
"#aec7e8",
"#ff7f0e",
"#2ca02c",
"#98df8a",
"#d62728",
"#ff9896",
"#9467bd",
"#c5b0d5"
"width": 6,
"height": 8,
"className": "",
"x": 356.0994567871094,
"y": 199.09091186523438,
"id": "2e3b032902dae011",
"type": "ui-group",
"name": "Chart-test",
"page": "804d82131cd00633",
"width": "6",
"height": "1",
"order": -1,
"showTitle": true,
"className": "",
"visible": "true",
"disabled": "false"
"id": "804d82131cd00633",
"type": "ui-page",
"name": "ui-chart issue",
"ui": "e0b25391ffd62b23",
"path": "/page5",
"icon": "home",
"layout": "grid",
"theme": "156fbe7869a5bfa8",
"order": -1,
"className": "",
"visible": "true",
"disabled": "false"
"id": "e0b25391ffd62b23",
"type": "ui-base",
"name": "myDB2",
"path": "/dashboard",
"showPathInSidebar": false
"id": "156fbe7869a5bfa8",
"type": "ui-theme",
"name": "basic",
"colors": {
"surface": "#ffffff",
"primary": "#0094ce",
"bgPage": "#eeeeee",
"groupBg": "#ffffff",
"groupOutline": "#cccccc"
