No sure what I ve done, but the dashboard loads ok, but just shows a blank page no errors (localhost:1880/ui/)
I am sure it worked before.
Information below:
Environment:
HW Pi2
NR v0185
Dash ver: 2.12.1
Screenshot:
Log:
pi@raspberrypi:~ $ node-red -log
14 Dec 10:31:44 - [info]
Welcome to Node-RED
14 Dec 10:31:44 - [info] Node-RED version: v0.18.5
14 Dec 10:31:44 - [info] Node.js version: v8.11.3
14 Dec 10:31:44 - [info] Linux 4.14.52-v7+ arm LE
14 Dec 10:31:46 - [info] Loading palette nodes
14 Dec 10:31:56 - [info] Dashboard version 2.12.2 started at /ui
14 Dec 10:31:59 - [info] Settings file : /home/pi/.node-red/settings.js
14 Dec 10:31:59 - [info] User directory : /home/pi/.node-red
14 Dec 10:31:59 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
14 Dec 10:31:59 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
14 Dec 10:31:59 - [error] Unable to listen on http://127.0.0.1:1880/
14 Dec 10:31:59 - [error] Error: port in use
The Flow: Just a slider and gauge
[{"id":"36fce3a2.8fc19c","type":"ui_slider","z":"8bed80ab.a57f","name":"","label":"slider","tooltip":"","group":"4b83e494.d25e2c","order":2,"width":0,"height":0,"passthru":true,"outs":"all","topic":"","min":0,"max":10,"step":1,"x":176,"y":304,"wires":[["4f671ff9.34786"]]},{"id":"4f671ff9.34786","type":"ui_gauge","z":"8bed80ab.a57f","name":"","group":"4b83e494.d25e2c","order":1,"width":0,"height":0,"gtype":"gage","title":"gauge","label":"units","format":"{{value}}","min":0,"max":10,"colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":341,"y":307,"wires":},{"id":"4b83e494.d25e2c","type":"ui_group","z":"","name":"Default","tab":"bbd7322e.c5c82","disp":true,"width":"6","collapse":false},{"id":"bbd7322e.c5c82","type":"ui_tab","z":"","name":"Home","icon":"dashboard"}]
Thanks,
Ken
