UI media in NodeRed Dashboard
How to add some pict in NodeRed Dashboard?
I install
node-red-contrib-ui-media
but i have error when insert the .png file. my error is :
16 Jun 14:55:49 - [red] Uncaught Exception:
16 Jun 14:55:49 - TypeError: path must be absolute or specify root to res.sendFile
at ServerResponse.sendFile (E:\node-red\node_modules\express\lib\response.js:425:11)
at C:\Users\muham.node-red\node_modules\node-red-contrib-ui-media\ui_media.js:288:17
at FSReqCallback.oncomplete (fs.js:171:23)
so what did you specify as the path to the file?
where is the .png file located on the machine running NR?
How to configure specify path?
Please export your flow and attach it to a reply. In order to make code more readable and importable it is important to surround your code with three backticks
like this
You can edit and correct your post by clicking the pencil icon.
