UI nodes missing after updating node-red on windows
I get the following warning when I start node-red on my windows machine, and my ui nodes are missing.
16 Feb 11:30:42 - [warn]
your credentials.
I do not understand where the the key is located or how to reset it. I have tried removing and reinstalling node-red but it did not help.
Can anyone help me get this going?
Thanks for any help.
This is a warning only and will not be the cause for UI nodes being lost.
Can you post the full startup log, use the </> button at the top of the forum entry window when pasting it in.
Also explain what you mean by the nodes being missing. Where are they missing from.
I assumed that the warning had something to do the the ui/dashboard nodes missing. I did not realize that that I need to reinstall the ' node-red-dashboard' now that I have I think I'm all good.
Thanks for the help, sorry for being a noob...
How did it become uninstalled?
the install of node red on this laptop was really old, i recently updated it and I think that is what removed the dashboard nodes.
That would certainly not normally happen during an update.
Did you not get a Flows Stopped due to missing nodes message?
