Ui_slider auto switch to previous or next tab when range is at either end
I have a flow with a slider in one of the tabs. When I move the slider to 0 it automatically moves to the previous tab. When I move the slider to 100 it automatically moves to the next tab.
I am using node-red on windows 10.
Node-RED version: v1.0.3
Node.js version: v12.16.0
Dashboard version 2.19.4
Windows_NT 10.0.18362 x64 LE
[{"id":"8e392b42.cb9d18","type":"ui_button","z":"2550e84d.cdda7","name":"","group":"32b0644e.b8807c","order":0,"width":0,"height":0,"passthru":false,"label":"button","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":450,"y":100,"wires":[[]]},{"id":"d446050b.475bc8","type":"ui_slider","z":"2550e84d.cdda7","name":"","label":"slider","tooltip":"","group":"e244ef19.ea7a5","order":0,"width":0,"height":0,"passthru":true,"outs":"end","topic":"axiomSH/TO/LivingR","min":0,"max":"100","step":"5","x":450,"y":180,"wires":[[]]},{"id":"ef522cce.f778","type":"ui_switch","z":"2550e84d.cdda7","name":"","label":"switch","tooltip":"","group":"72ca9244.d2caac","order":5,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":680,"y":60,"wires":[[]]},{"id":"32b0644e.b8807c","type":"ui_group","z":"","name":"Lights","tab":"f711b455.dd74f8","order":1,"disp":true,"width":"6","collapse":false},{"id":"e244ef19.ea7a5","type":"ui_group","z":"","name":"Lights","tab":"5c7e3cb9.4dc504","order":1,"disp":true,"width":"6","collapse":false},{"id":"72ca9244.d2caac","type":"ui_group","z":"","name":"Electric Panel","tab":"a33f0dbc.08976","order":1,"disp":true,"width":"4","collapse":false},{"id":"f711b455.dd74f8","type":"ui_tab","z":"","name":"Kitchen","icon":"kitchen","order":4,"disabled":false,"hidden":false},{"id":"5c7e3cb9.4dc504","type":"ui_tab","z":"","name":"Living Room","icon":"fa-tv","order":2,"disabled":false,"hidden":false},{"id":"a33f0dbc.08976","type":"ui_tab","z":"","name":"Main","icon":"home","order":1,"disabled":false,"hidden":false}]
I tried a button and switch. they do not exhibit this behavior.
Tried searching and did not get any hits.
Any suggestions on where to go from here, or if there is a site that discusses this
thx
I could not reproduce the weird behaviour your mentioned. Do you have an ui_control node connected to the ui_slider node ?
Try disabling the "no swipe between tabs"
Thank you.
No swipe between tabs DID IT...
why did this option cause the slider to switch tabs?
