Hi all,
First of all, thank you very much for the forum, it's really helpful!
My problem :
I created 3 sub-flows, each sub-flow is related to a type of device (eg: temperature sensor, pressure sensor), in these sub-flows I do data processing and dashboard display (ui_text, ui_chart)
I have multiple instances of these 3 sub-flows. (eg: 3 temperature sensors, 2 pressure sensors)
Each sensor has an ID (eg: Temp1, Temp2, Temp3, Pres1, Pres2)
Basically I want to display a list of devices.
So, whenever i have a new instance i want a new tab (named sensor id) with the ui element (graphic and text) under the same group (named device list).
So I tried setting the ui tab name from the environment variables set in the sub-flow settings.
[List of devices] $ {SENSOR_ID}
This works fine for one sub-flow (I have 3 Tab under "list of devices" group, Temp1, Temp2, Temp3)
but if I try to do the same in a second sub-flow, the environment variable is not "recognized" and all instances of that sub-flows are grouped into one tab named "$ {SENSOR_ID}"
do you know what i'm missing or is it even possible to do what i want this way?
Thank you for your time !
