Hi there,
Cant seem to make ui_table custom column size work on linux (tested on rasbian with chromium and firefox), it works perfectly on windows.
The tables are defined in percentages.
When the page is loaded the columns are all sized to the left of the column. Not as defined by the columns sizes on the ui_table node.
If i update the table after the page is loaded , it scales correctly.
Is there a fix for this ? Am I missing something ?
