Ui template: content disappeared on send
hope someone can help
My content disappeared after trigger the angular js send function :sweat:
        "id": "b17f4e2518ccb979",
        "type": "ui_template",
        "z": "08f7a2f8d6e59272",
        "group": "252497966a12284e",
        "order": 7,
        "width": "6",
        "height": "9",
        "format": "<div>\n    <div>\n        <h2>Test</h2>\n    </div>\n    <ul class=\"group_ul\">\n        <li class=\"group_li\" ng-repeat=\"x in msg.group.config\">\n            {{x.group}}\n            <span style=\"float:right;\"> > </span>\n\n            <ul class=\"device_ul\">\n                <li class=\"device_li\" ng-repeat=\"y in msg.device[x.id]\" ng-click=\"send({'topic':'test'})\">\n                    {{y.device}}\n                </li>\n            </ul>\n        </li>\n    </ul>\n</div>\n\n\n<style>\n.group_ul, .device_ul {\n  list-style: none;\n  margin-left: 0;\n  padding-left: 0;\n}\n\n.group_li, .device_li {\n  padding-left: 1em;\n  text-indent: -1em;\n}\n\n.group_li:before {\n  content: \"📁\";\n  padding-right: 5px;\n}\n/*\n.device_ul{\n  display: none;\n  transition: opacity 1s ease-out;\n  opacity: 0;\n}\n*/\n</style>\n",
        "storeOutMessages": true,
        "fwdInMessages": false,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 400,
        "y": 1740,
                "1bfd41e1a17249b4"
        "id": "119685c4c8a8bf91",
        "type": "inject",
        "props": [],
        "repeat": "",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "x": 110,
        "y": 1740,
                "32bea2e5754a53db"
        "id": "32bea2e5754a53db",
        "type": "function",
        "func": "msg.group = {\"config\":[{\"group\":\"Line 1\",\"id\":1659579567271,\"view\":\"View\",\"edit\":\"Edit\",\"delete\":\"Delete\"},{\"group\":\"Line 3\",\"id\":1659945257868,\"view\":\"View\",\"edit\":\"Edit\",\"delete\":\"Delete\"},{\"group\":\"Line 2\",\"id\":1660202500870,\"view\":\"View\",\"edit\":\"Edit\",\"delete\":\"Delete\"},{\"group\":\"Line 4\",\"id\":1660266656455,\"view\":\"View\",\"edit\":\"Edit\",\"delete\":\"Delete\"}]}\n\nmsg.device = {\"1659579567271\":[{\"device\":\"Secure Elite 300\",\"unit_id\":\"1\",\"id\":1659579600607,\"view\":\"View\",\"edit\":\"Edit\",\"delete\":\"Delete\"}],\"1660202500870\":[{\"device\":\"Device 2.0\",\"unit_id\":\"2\",\"id\":1660202587497,\"view\":\"View\",\"edit\":\"Edit\",\"delete\":\"Delete\"}],\"1659945257868\":[{\"device\":\"Drive 3\",\"id\":1660203460465,\"view\":\"View\",\"edit\":\"Edit\",\"delete\":\"Delete\",\"unit_id\":\"1\"}]}\n\n\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 240,
        "y": 1740,
                "b17f4e2518ccb979"
        "id": "1bfd41e1a17249b4",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 530,
        "y": 1720,
        "id": "252497966a12284e",
        "type": "ui_group",
        "name": "Default",
        "tab": "499954d8f07402af",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "499954d8f07402af",
        "type": "ui_tab",
        "name": "Setting: Modbus Signal 2",
        "icon": "",
        "disabled": false,
        "hidden": false
Try unchecking Add output messages to stored state. in the ui-tmplate node.
ok thanks :slight_smile:
