UI Template full screen
I Know this may be a simple question but i have been trying to display a weight full screen as large a possible . i cant seem to get the font large enough. i am using this as a remote scale display. any help would be appreciated.
If you want to use the template node, you need to add a group with the width matching your target resolution and then set the size of the template node manually to fill it. But you would be limited to one screen size.
Since you want to use a template node filling the whole screen you might be better off with alternatives such as uibuilder. That gives you complete freedom.
