Hi all,
I successfully integrated Plotly charts into my Dashboard 2.0 using ui-template. But I'm having problem sizing ui-template inside the dashboard group. If I set the ui-template size as auto in node properties, the chart is displayed as compressed in height.
If I set the size to 12x6, I am able to see the chart correctly.
The size of group containing ui-template is set to 12x6.
Why does this happen? How can I make the ui-template size expanded to the size of the group?
Thanks in advance.
Below is my flow for the ui-template
"id": "d6682ace35ba3d31",
"type": "ui-template",
"z": "415d536515768e0b",
"group": "0db8d9f5bdc794eb",
"page": "",
"ui": "",
"name": "Plotly Example",
"order": 2,
"width": "12",
"height": "6",
"head": "",
"format": "<template>\n <div id='myDiv'><!-- Plotly chart will be drawn inside this DIV -->\n</template>\n\n<script src='https://cdn.plot.ly/plotly-2.35.0.min.js'></script>\n\n<script>\n export default {\n mounted() {\n // code here when the component is first loaded\n let interval = setInterval(() => {\n if (window.Plotly) {\n clearInterval(interval);\n this.draw()\n }\n }, 100);\n },\n methods: {\n draw () {\n \n var t1 = [20, 14, 39];\n var t2 = [12, 18, 29];\n\n var trace1 = {\n x: ['giraffes', 'orangutans', 'monkeys'],\n y: t1,\n name: 'SF Zoo',\n type: 'bar',\n text: t1.map(String),\n textposition: 'auto',\n hoverinfo: 'none',\n marker: {\n color: '#207fcd',\n opacity: 0.6,\n line: {\n color: 'rgb(8,48,107)',\n width: 1.5\n }\n }\n };\n\n var trace2 = {\n x: ['giraffes', 'orangutans', 'monkeys'],\n y: t2,\n name: 'LA Zoo',\n type: 'bar',\n text: t2.map(String),\n textposition: 'auto',\n hoverinfo: 'none',\n marker: {\n color: 'rgb(158,202,225)',\n opacity: 0.6,\n line: {\n color: 'rgb(8,48,107)',\n width: 1.5\n }\n }\n };\n\n var data = [trace1, trace2];\n\n var layout = { \n title: 'Responsive to window\\'s size!',\n font: {size: 18}\n };\n var config = {responsive: true}\n Plotly.newPlot('myDiv', data, layout, config );\n }\n }\n }\n</script>",
"storeOutMessages": true,
"passthru": true,
"resendOnRefresh": true,
"templateScope": "local",
"className": "",
"x": 440,
"y": 1380,
"id": "0db8d9f5bdc794eb",
"type": "ui-group",
"name": "My Group",
"page": "92d2e5483adf6001",
"width": "12",
"height": "6",
"order": 1,
"showTitle": true,
"className": "",
"visible": "true",
"disabled": "false"
"id": "92d2e5483adf6001",
"type": "ui-page",
"name": "Simulation",
"ui": "caf9593480b4ab3b",
"path": "/page1",
"icon": "home",
"layout": "grid",
"theme": "d8f055e104cc1454",
"order": 1,
"className": "",
"visible": "false",
"disabled": "false"
"id": "caf9593480b4ab3b",
"type": "ui-base",
"name": "My Dashboard",
"path": "/dashboard",
"includeClientData": true,
"acceptsClientConfig": [],
"showPathInSidebar": false,
"showPageTitle": true,
"navigationStyle": "default",
"titleBarStyle": "default"
"id": "d8f055e104cc1454",
"type": "ui-theme",
"name": "Default Theme",
"colors": {
"surface": "#ffffff",
"primary": "#0094CE",
"bgPage": "#eeeeee",
"groupBg": "#ffffff",
"groupOutline": "#cccccc"
"sizes": {
"pagePadding": "12px",
"groupGap": "12px",
"groupBorderRadius": "4px",
"widgetGap": "12px"
