If the "Mode" property for a Text Input UI Dashboard node is changed to color, time, month, week etc. picker the state (value) is not saved as is with all the other controls included as part of the Dashboard. Note that the state is saved if the Mode property is set to the default value of "Text Input". By "not saved" I mean if you close the UI browser window and then reopen it, the previously selected value is gone.
I'm trying to figure out a good workaround to refresh the value
The obvious solution is to save the state in a flow level variable and then send an input message with the payload set to the stored value. However, I cannot find a way to detect an event for "UI browser opened". One solution is to use an Inject Node that repeats every second. This results in lots of mostly unnecessary messages and therefore is not an efficient solution. Any suggestions would be greatly appreciated. Thanks!
