Hi all
I'm using ui text ui table ui notify and I would write multi-line text. I try passing a payload with "\n" but not work.
Can someone help me?
You really need to provide a bit more if you want some help. How about creating a small flow demonstration your issue and then you can export it and attach it to a reply. That way people can see what you are currently doing.
You can display multi-line text in a dashboard text node like this:
"id": "28b1b2ddd3155eb6",
"type": "ui_text",
"z": "12f7dc31296fd47a",
"group": "a6e358b.672ffa8",
"order": 7,
"width": "6",
"height": "3",
"label": "text",
"format": "{{msg.payload}}",
"layout": "row-spread",
"className": "",
"x": 630,
"y": 40,
"id": "b3170ca4f76ddaa5",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "Ottowa<p>Washington DC<p>Mexico City<p>Belmopan<p>Tegucigalpa<p>Guatemala City<p>",
"payloadType": "str",
"x": 490,
"y": 40,
"28b1b2ddd3155eb6"
"id": "a6e358b.672ffa8",
"type": "ui_group",
"name": "Demo",
"tab": "4e528085.a1bfa",
"order": 1,
"disp": true,
"width": "20",
"collapse": false
"id": "4e528085.a1bfa",
"type": "ui_tab",
"name": "Demo",
"icon": "dashboard",
"order": 2,
"disabled": false,
"hidden": false
thank you very much, just one more question
If I would like a text box with a fixed width can i set the text in multiline mode automatically. or better can the text adapt to cell dimension in multiline mode?
many thanks for your help
