Ui template or ui text formated string
Hey guys, I have a telegram from smartmeter, and it looks like this when I debug,
That looks very good. But when I feed this to ui template or ui text, then it looks like this,
afbeelding
Can anyone tell me, how to keep the format?
You need to replace the new lines with <br> tags.
One way is a change node using the regular expression (?:\r\n|\r|\n) which replaces DOS \r\n as well as Unix \n
Untitled 2
You need the display to use a fixed-width font and to retain the line-feeds. In HTML, the easy way to do that is to wrap the text with <pre>...</pre>. You can use a template to do that.
I tried your suggestion,
afbeelding
But the result wasn't quite good yet....
afbeelding
@TotallyInformation You were right. This is the result,
The fixed-width font was automatically set, by the way.
Only pitty a little bit that the font was changed, but I can live with that.
@TotallyInformation and @jbudd , thank you all guys for your help, I appreciate it very much.
Is that output to a template? I tried it with a UI text node.
Anyway of course Julian's answer was better! :grinning:
You can change the font in Dashboard. Using CSS.
@TotallyInformation , you were right again. Here is the result,
I am not very familiar with HTML and CSS but I managed,
afbeelding
That's why the internet was invented :grinning:
I always have to look stuff up as well.
@TotallyInformation , indeed, and I learned most of W3schools. :grinning:
