I tried out the ui-time-sheduler on 3 node-red installations. On two of them the sheduler did not show up in the ui. I tried to update node.js and node-red but it did not help. The two installations was one on a pi4 and the other on Windows. The one working is also a pi4. I cannot see what is different.
Just checking to see what dashboard you are trying to use. That node does not work on the new dashboard 2,
Thanks a lot for you fast answer
