I am not sure this is what you mean, but here is an extract of something I have.
You will also need this file:
(plants.txt)
{"timers":[{"starttime":1606528500000,"days":[1,1,1,1,1,1,1],"output":"0","endtime":1606529100000},{"starttime":1616723700000,"days":[0,0,1,0,1,0,1],"output":"1","endtime":1616724300000}]}
Nodes:
You will have to edit the path to the file.
[{"id":"b5a97d4f.84ed58","type":"function","z":"6dd5ca4d.d1958c","name":"build message","func":"var path = global.get(\"event_paths\");\nmsg.filename = path + \"plants.txt\";\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":880,"y":4680,"wires":[["82e4dfc5.1ba768"]]},{"id":"82e4dfc5.1ba768","type":"file in","z":"6dd5ca4d.d1958c","name":"Plants","filename":"","format":"utf8","chunk":false,"sendError":false,"encoding":"none","x":850,"y":4730,"wires":[["46e58700.dc6b38"]]},{"id":"46e58700.dc6b38","type":"ui_time_scheduler","z":"6dd5ca4d.d1958c","group":"c0eea23d.14fd5","name":"Plants","refresh":"60","devices":["Daily","Away"],"customPayload":false,"eventMode":false,"outputs":3,"order":11,"width":"6","height":"1","x":1040,"y":4730,"wires":[["39958344.67685c"],["4e17f8ac.78c5c8","8a49b79e.e2e9d"],["4e17f8ac.78c5c8","c133b660.f9987"]]},{"id":"c0eea23d.14fd5","type":"ui_group","name":"Automatic plant watering","tab":"e92ac76d.c24e7","order":12,"disp":true,"width":"6","collapse":false},{"id":"e92ac76d.c24e7","type":"ui_tab","name":"Real_World_Control","icon":"dashboard","order":14,"disabled":false,"hidden":false}]
