I am in the midst of the Bootstrap tutorial on W3Schools.com and found this example for a split button with a dropdown.
<div class="container">
<h2>Split Buttons</h2>
<div class="btn-group">
<button type="button" class="btn btn-primary">Sony</button>
<button type="button" class="btn btn-primary dropdown-toggle" data-toggle="dropdown">
<span class="caret"></span>
</button>
<ul class="dropdown-menu" role="menu">
<li><a href="#">Tablet</a></li>
<li><a href="#">Smartphone</a></li>
</ul>
</div>
</div>
It looks like this when activated:
The issue is that when I use the inclusion that came with the default uibuilder example which follows, it doesn't work.
<script src="../uibuilder/vendor/bootstrap-vue/dist/bootstrap-vue.js"></script>
I was however able to get it to work by replacing that with this which I pulled from w3schools example:
<script src="https://ajax.googleapis.com/ajax/libs/jquery/3.5.1/jquery.min.js"></script>
<script src="https://maxcdn.bootstrapcdn.com/bootstrap/3.4.1/js/bootstrap.min.js"></script>
Does anyone have any insight into why this doesn't work using the default? Should I just plan to use the cdn sourced inclusion going forward?
