UIBUILDER-Help- HTML Table
I am trying to display a html table in the uibuilder, the table is displayed, but i am unable to control the width to my requirement. the same set of html tags obey correctly in dashboard-1
I changed the display default to flexbox in the css file.
display: flexbox;
The layout is perfect for me, however i am unable to control the cell width.
below my index.html and index.css files.
PS: I have several other questions (which i am trying to find answers in the forum) will raise them if I dont get success..
[{"id":"0007173c4b498ca7","type":"template","z":"8ad51e99d084f0bf","g":"94a98c028fff17dd","name":"index.css","field":"payload","fieldType":"msg","format":"css","syntax":"plain","template":"/* Load defaults from `<userDir>/node_modules/node-red-contrib-uibuilder/front-end/uib-brand.min.css`\n * This version auto-adjusts for light/dark browser settings.\n */\n@import url(\"../uibuilder/uib-brand.min.css\");\n\n/* CSS variables to make it easier to control */\n:root {\n    /* The layout container */\n    --container-max-width: 1366px;\n    --container-col-gap: 0.2rem;\n    --container-row-gap: 0.2rem;\n\n    /* The main content container */\n    --main-cols: repeat(20, 1fr);\n    --main-rows: auto;\n    /* auto OR repeat(12, 1fr); ... */\n    --main-col-gap: var(--container-col-gap);\n    --main-row-gap: var(--container-row-gap);\n\n    /* The articles */\n    --article-width: 1;\n    /* number of columns or auto */\n    --article-height: auto;\n    /* auto or number of rows */\n\n    /* The Sidebar container */\n    --sidebar-max-width: 1fr;\n    --sidebar-min-width: 0.1fr;\n}\n\n\n/* The outer container div */\n.container {\n    width: 100%;\n    max-width: var(--container-max-width);\n    margin: 0 auto;\n    /* Center the container horizontally */\n    display:felxbox;\n    gap: var(--container-row-gap) var(--container-col-gap);\n\n    /* 2 cols x 3 rows layout. Middle row & right column are larger. Left col is constrained min/max */\n    grid-template-columns: minmax(var(--sidebar-min-width), var(--sidebar-max-width)) var(--main-width);\n    grid-template-rows: 0fr 1fr 0fr;\n    grid-template-areas:\n        \"header header\"\n        \"sidebar main\"\n        \"sidebar footer\";\n    justify-items: stretch;\n}\n\n/* The main content container */\nmain {\n    /* Where you put your content */\n    grid-area: main;\n\n    display: grid;\n    gap: var(--main-row-gap) var(--main-col-gap);\n    grid-template-columns: var(--main-cols, 12);\n    /* fallback to 12 cols */\n    grid-template-rows: var(--main-rows, auto);\n    /* fallback to auto */\n}\n\n/* Any article within the main container.\n   You can use a div instead of an article, useful for no-code uibuilder elements. */\nmain>article,\nmain>div {\n    /* Width of an article in number of columns */\n    grid-column: span var(--article-width);\n    /* Height of an article in number of rows */\n    grid-row: span var(--article-height);\n    margin: 0;\n}\n\n/* Set a child div to have same format as an article */\nmain>div {\n    border: 1px solid var(--text3);\n    border-radius: var(--border-radius);\n    padding: var(--border-pad);\n    margin: 0;\n    background-color: var(--surface3);\n}\n\nmain>div>h2,\nmain>div>h3,\nmain>div>h4 {\n    margin-block-start: 0;\n    border-bottom: 1px solid var(--text3);\n    padding-block-end: var(--border-pad);\n}\n\nheader {\n    /* Headings, nav, etc */\n    grid-area: header;\n}\n\nfooter {\n    /* at the bottom, (c), dates, etc */\n    grid-area: footer;\n    margin-top: 0;\n}\n\n/* We might want other sidebars so be more explicit for this */\naside.sidebar {\n    /* stuff to one side of the main content */\n    grid-area: sidebar;\n}\n\n/*#region Simple horizontal navigation main menu (in the header) */\n.nav-main {\n    background-color: var(--surface3);\n}\n\n.nav-main ul {\n    /* Remove bullet points */\n    list-style-type: none;\n    /* Remove default padding */\n    padding: 0;\n    /* Remove default margin */\n    margin: 0;\n    /* Use Flexbox to align items horizontally */\n    display: flex;\n}\n\n/* Add space between menu items */\n.nav-main li {\n    margin-right: 1rem;\n}\n\n/* Remove margin on the last item */\n.nav-main li:last-child {\n    margin-right: 0;\n}\n\n.nav-main a {\n    /* Remove underline from links */\n    text-decoration: none;\n    /* Add padding for better click area */\n    padding: var(--border-pad);\n    /* Ensure the entire area is clickable */\n    display: block;\n}\n\n/* Highlight on hover */\n.nav-main a:hover {\n    background-color: var(--surface5);\n    /* Optional: Add rounded corners */\n    border-radius: var(--border-radius);\n}\n\n/*#endregion */\n\n/*#region simple vertical navigation menu */\n.nav-side {\n    background-color: var(--surface3);\n}\n\n.nav-side ul {\n    /* Remove bullet points */\n    list-style-type: none;\n    /* Remove default padding */\n    padding: 0;\n    /* Remove default margin */\n    margin: 0;\n}\n\n.nav-side a {\n    /* Remove underline from links */\n    text-decoration: none;\n    /* Add padding for better click area */\n    padding: 0.5rem 1rem;\n    /* Ensure the entire area is clickable */\n    display: block;\n}\n\n/* Highlight on hover */\n.nav-side a:hover {\n    background-color: var(--surface5);\n}\n\n/*#endregion */\n\n/* Adapt for narrow screens */\n@media only screen and (max-width: 512px) {\n    :root {\n        /* --article-width: 12; */\n    }\n\n    /* Very simple adaption example, a single column, 4 rows */\n    .container {\n        gap: 0.5rem;\n\n        /* 1 cols x 4 rows layout. 2nd row is larger */\n        grid-template-columns: 1fr;\n        grid-template-rows: 0.1fr 1fr 0.1fr 0.1fr;\n        grid-template-areas:\n            \"header\"\n            \"main\"\n            \"sidebar\"\n            \"footer\";\n    }\n\n    /* We want the articles in a single col now so just display as block */\n    main {\n        display: block;\n    }\n\n    /* And add a bit of a top margin to articles for clarity */\n    main>article,\n    main>div {\n        margin-top: 0.5em;\n    }\n}\n\n.smallfont {    font-family: \"arial narrow\";\n    font-size: 0.8em;    color: cyan;\n    text-align: center;    font-weight: 100;\n}\n.mf1 {\n    font-size: 1rem;\n    color: yellow;\n    font-family: \"arial narrow\";\n    text-align: right;\n    background: #252525;\n}\n\n.raw-input {\n    font-size: 1.2em;\n    color: white;\n    text-align: center;\n    font-weight: 200;\n}\n.large-font-r {\n    border-radius: 10px;\n    font-size: 1.25em;\n    background: black;\n    color: white;\n    font-family: \"Trebuchet MS\";\n    text-align: center;\n}\n\n.large-font-b {\n    border-radius: 10px;\n    font-size: 1.8em;\n    background: #101010;\n    color: white;\n    font-family: \"Trebuchet MS\";\n    text-align: center;\n}\n\n.large-font-g {\n    border-radius: 10px;\n        font-size: 1.8em;\n        background: green;\n        color: white;\n        font-family: \"Trebuchet MS\";\n        text-align: center;}\n\n.table1 {\n    border-radius: 10px;\n    height:15px !important;\n    font-size: 1.5em;\n    background: black;\n    color: white;\n    text-align: center;\n}","output":"str","x":610,"y":900,"wires":[["9755d35070145c84"]]},{"id":"6d9227ab15f1708b","type":"template","z":"8ad51e99d084f0bf","g":"94a98c028fff17dd","name":"index.html","field":"payload","fieldType":"msg","format":"html","syntax":"mustache","template":"<!doctype html>\n<html lang=\"en\"><head>\n\n    <meta charset=\"utf-8\">\n    <meta name=\"viewport\" content=\"width=100%, initial-scale=1\">\n    <link rel=\"icon\" href=\"../uibuilder/images/node-blue.ico\">\n\n    <title>Dashboard</title>\n    <meta name=\"description\" content=\"Node-RED uibuilder - Dashboard Layout\">\n\n    <!-- Your own CSS (defaults to loading uibuilders css)-->\n    <link type=\"text/css\" rel=\"stylesheet\" href=\"./index.css\" media=\"all\">\n\n    <!-- #region Supporting Scripts. These MUST be in the right order. Note no leading / -->\n    <script defer src=\"https://cdn.jsdelivr.net/npm/markdown-it/dist/markdown-it.min.js\"></script>\n    <script defer src=\"../uibuilder/uibuilder.iife.min.js\"></script>\n    <!-- <script defer src=\"./index.js\">/* <= OPTIONAL: Put your custom code in that */</script> -->\n    <!-- #endregion -->\n\n</head><body>\n\n    <div class=\"container\">\n        <header class=\"header\">\n<!--            <h1 class=\"with-subtitle\">Dashboard Live</h1>\n   -->\n   \n<button id= \"button1\" type=\"button\" onclick=\"uibuilder.eventSend(event)\">Live</button>\n<button id= \"button2\" type=\"button\" onclick=\"uibuilder.eventSend(event)\">Trends</button>\n<button id= \"button3\" type=\"button\" onclick=\"uibuilder.eventSend(event)\">Downtime</button>\n<button id= \"button4\" type=\"button\" onclick=\"uibuilder.eventSend(event)\">Temperature</button>\n\n        </header>\n\n        <main id=\"more\"><!-- '#more' is used as a parent for dynamic HTML content in examples -->\n    \n    <table width=\"100%\" border=\"1px solid white\" border-collapse=\"collapse\">\n\n        <tbody>\n            <tr class=\"table1\">\n\n                <td id= \"time\"  col width=\"200px\" rowspan=\"2\" class=\"mf1\">PLC Time</td>\n                <th width=\"80px\">CR03</th>\n                <th width=\"80px\">MSP1</th>\n                <th width=\"80px\">BTP1</th>\n                <th width=\"80px\">SP04</th>\n                <th width=\"80px\">SP03</th>\n                <th width=\"80px\">PFSL</th>\n                <th width=\"80px\">PFSR</th>\n                <th width=\"80px\">CR01</th>\n                <th width=\"80px\">CSDL</th>\n                <th width=\"80px\">CFTJ</th>\n                <th width=\"80px\">14TR</th>\n                <th width=\"80px\">12TR</th>\n                <th width=\"80px\">BTP2</th>\n                <th width=\"80px\">BTP3</th>\n                <th width=\"80px\">SP05</th>\n                <th width=\"80px\">AP02</th>\n                <th width=\"80px\">MSP2</th>\n                <th width=\"80px\">BAGR</th>\n                <th width=\"80px\">DIPS</th>\n                \n            </tr>\n            <tr>\n                <td id= \"cm00\" width=\"80px\" class=\"large-font-b\">-</td>\n                <td id= \"cm01\" width=\"80px\" class=\"large-font-b\">-</td>\n                <td id= \"cm02\"  width=\"80px\" class=\"large-font-b\">-</td>\n                <td id= \"cm03\"  width=\"80px\" class=\"large-font-b\">-</td>\n                <td id= \"cm04\"  width=\"80px\" class=\"large-font-b\">-</td>\n                <td id= \"cm05\"  width=\"80px\" class=\"large-font-b\">-</td>\n                <td id= \"cm06\"  width=\"80px\" class=\"large-font-b\">-</td>\n                <td id= \"cm07\"  width=\"80px\" class=\"large-font-b\"><b>-</b></td>\n                <td id= \"cm08\" width=\"80px\" class=\"large-font-b\"><b>-</b></td>\n                <td id= \"cm09\"  width=\"80px\" class=\"large-font-b\">-</td>\n                <td id= \"cm10\"  width=\"80px\" class=\"large-font-b\">-</td>\n                <td id= \"cm11\"  width=\"80px\" class=\"large-font-b\">-</td>\n                <td id= \"cm12\"  width=\"280px\" class=\"large-font-b\"><b>-</b></td>\n                <td id= \"cm13\"  width=\"280px\" class=\"large-font-b\"><b>-</b></td>\n                <td id= \"cm14\"  width=\"80px\" class=\"large-font-b\">-</td>\n                <td id= \"cm15\"  width=\"80px\" class=\"large-font-b\">-</td>\n                <td id= \"cm16\"  width=\"80px\" class=\"large-font-b\">-</td>\n                <td id= \"cm17\"  width=\"80px\" class=\"large-font-b\"><b>-</b></td>\n                <td id= \"cm18\"  width=\"80px\" class=\"large-font-b\">-</td>\n            </tr>\n        </tbody>\n    </table>\n\n\n\n</md-card>\n        </main>\n        \n\n<!--        <aside class=\"sidebar\">\n            <nav class=\"nav-side\">\n                <ul>\n                    <li><a href=\"#nav1\">Nav 1</a></li>\n                    <li><a href=\"#nav2\">Nav 2</a></li>\n                    <li><a href=\"#nav3\">Nav 3</a></li>\n                </ul>\n            </nav>\n        </aside>\n\n        <footer>\n            The footer\n            <div>2nd footer</div>\n        </footer>\n-->\n    </div>\n\n</body></html>\n","output":"str","x":600,"y":820,"wires":[["9755d35070145c84"]]}]
Google Gemini helped me out,
            table-layout: fixed;
this resolved the issue.
i have a glitch in the display when the counter goes to zero, probing the same.
uib-dash
The shared HTML does have some errors in it.
  • <table width="100%" border="1px solid white" border-collapse="collapse"> - width should be in CSS, border=... is invalid, border-collapse should be in CSS.
    You should note that if you use my uib-brand.css as a base set of styles, width and border-collapse are already included.
  • <td id= "time" col width="200px" rowspan="2" class="mf1">PLC Time</td> - col width=... is incorrect. Also 200px is around 12.5em.
  • You have set the "table1" id on the 1st tr instead of the table itself.
  • You have put the heading row into the tbody, there should be a separate thead containing the heading row. However, that prevents the time header from spanning to the tbody row. Sometimes HTML simply doesn't let you do what you want! Personally, I wouldn't span the rows, simply put the actual time into its own tbody cell. Move the "time" id to the tbody first cell
  • Your rowspan entry needs a corresponding td in the tbody row.
  • You had a space between an attribute name and the = sign.
  • You have set fixed px widths which is bad practice. 80px ~= 5em.
  • You have used the width attribute which is no longer recommended. You should simply set a CSS style for th and td.
  • Some of the table cell values are wrapped in <b></b> and others are not. Some are empty.
  • You don't really need the same class on each td, just set the required style in CSS.
  • Setting background and foreground colours on the table itself doesn't really do anything. You have to set for the cells (th/td)
If you want to have a group of columns with a different format, you could use a <colgroup>.
The main issue you have with the table as a whole is that the fixed widths are wider than the allowed max width of the main and other containers. Especially with a larger font size. So the table is forced to overflow.
This is actually a case where a flex layout might be preferred.
So the following seems to be working though I've not set the green background. However, I think I may see the "glitch" problem - the font size for the class providing the green background to the cells does not match the td default.
css
main {
    border: 1px solid silver;
#table1 {
    width: 100%;
    height:1em;
    /* font-size: 1.5em; */
    --bg: black;
    --fg: white;
    th, td {
        width: 2em;
        text-align: center;
        border: 1px solid var(--surface5);
    thead th:nth-child(1) {
        width: 3.7em;
    td#time {
        color: orange;
    tbody td {
        background: var(--bg);
        color: var(--fg);
html (just the main section)
    <main>
        <table id="table1">
            <thead>
                <tr>
                    <th>PLC Time</th>
                    <th>CR03</th>
                    <th>MSP1</th>
                    <th>BTP1</th>
                    <th>SP04</th>
                    <th>SP03</th>
                    <th>PFSL</th>
                    <th>PFSR</th>
                    <th>CR01</th>
                    <th>CSDL</th>
                    <th>CFTJ</th>
                    <th>14TR</th>
                    <th>12TR</th>
                    <th>BTP2</th>
                    <th>BTP3</th>
                    <th>SP05</th>
                    <th>AP02</th>
                    <th>MSP2</th>
                    <th>BAGR</th>
                    <th>DIPS</th>
                </tr>
            </thead><tbody>
                <tr>
                    <td id="time">18:53:26</td>
                    <td id="cm00">6</td>
                    <td id="cm01">-</td>
                    <td id="cm02">-</td>
                    <td id="cm03">-</td>
                    <td id="cm04">-</td>
                    <td id="cm05">-</td>
                    <td id="cm06">-</td>
                    <td id="cm07">-</td>
                    <td id="cm08">304</td>
                    <td id="cm09">-</td>
                    <td id="cm10">-</td>
                    <td id="cm11">-</td>
                    <td id="cm12">108</td>
                    <td id="cm13">99</td>
                    <td id="cm14">-</td>
                    <td id="cm15">-</td>
                    <td id="cm16">-</td>
                    <td id="cm17">-</td>
                    <td id="cm18">-</td>
                </tr>
            </thead>
        </table>
            Also, send {topic:"more", payload:"Hello from <b>Node-RED</b>"} to auto-display the payload -->
        <div id="more" uib-topic="more"></div>
    </main>
    <script>
        const cm08 = document.getElementById('cm08')
        const cm00 = document.getElementById('cm00')
        setInterval(() => {
            cm08.innerText = uibuilder.round(Math.random() * 1000, 0)
            const smallNumber = Math.random() * 10
            cm00.innerText = smallNumber < 1 ? '-' : uibuilder.round(smallNumber, 0)
        }, 1000);
    </script>
Sorry, should have said that I've used nested CSS which will only work with fairly modern browsers.
thanks for your time in going through the flow so deeply. i agree, the HTML is not great, but it was a mix of copy paste from several areas and just put together to get it started.
implemented your inputs and its come to a decent shape.
now, i have 20 machines counters to update, and i have a mqtt feeding in the values in an array every second. do i have to add 20 uib-update nodes or is there a better way ?
below is the data input (captured for one second)
First 24 are the count (related to id #cm00 to #cm23) and last 6 are datetime information coming from the PLC.(s,m,h,d,M,yy)
[{"id":"91e0b712652678be","type":"inject","z":"8ad51e99d084f0bf","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"mqtt","payload":"[0,0,0,0,0,0,0,0,144,0,0,0,36,0,0,0,0,36,5,0,0,0,0,0,25,30,6,10,6,25]","payloadType":"json","x":260,"y":500,"wires":[["bcb2950b20455109"]]},{"id":"bcb2950b20455109","type":"debug","z":"8ad51e99d084f0bf","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":410,"y":500,"wires":[]}]
You would probably be better off simply sending the data to the front-end and processing it there.
Otherwise, you could examine the output from a uib-update and creating your own custom low-code output.
I would do it in the front end but then I am comfortable with using JavaScript.
Can you dumb it down please :slight_smile: . (sorry, i am not asking you do my homework, but this is new to me.)
or a simple example how to do it.
its not only the 20 counters which update every second, there are other tables whcih need to update every minute/hour/shift/day as well.
Shift and Day is ok, since its frequency is very low, i can manage doing it 'manually'.
