Hi all, another new UIBUILDER release. I hadn't intended another point release so soon but in the end too much new stuff ended up in the dev pipeline, so here we are. ![]()
Managed to squeeze in the new "Quick Start" guide that some have been calling for - good call by the way, I hope this helps.
Feature-wise, the new showOverlay notification message feature is a stand-out and should be useful to many.
Those who want to use front-end frameworks or other complex scripts, may welcome the new script runner tab in the uibuilder node. Saves you having to dip to a server command line for running build or other scripts. It picks up any script defined in the instance's package.json file and shows output right in the Editor.
Plenty of other new and updated things as well so please do check the log below. Plenty of bug-fixes in this release as usual.
Following on from the recent attacks on the npm platform, code, release and package security has been tightened still further.
Finally, for anyone who follows dev releases, from now-on, there will be a persistent dev branch in GitHub.
Changelog
Code commits since last release.
NOTE: If using the uibRouter SPA client library, please note that the startup processing has changed slightly. You may now get an error if you have specified a route container element but it doesn't exist. Unfortunately, some of the examples shared have this error and so will now break unless that container element id is changed. Sorry about that. The built-in router/SPA example has been updated to reflect this change.
Highlights
New "Quick Start" guides added to the documentation. Two main approaches: no-code/low-code and low-code/custom code. Each approach has a step-by-step guide to get you started quickly. In addition, several documentation pages now have rotating "tips" selected randomly from a list, they change every 15 seconds.
A new browser overlay notification message feature available. Using
showOverlayallows messages of different types (info, success, warning, and error) to be displayed to users in the browser. This can be triggered from Node-RED or from front-end code. Messages can be auto-dismissed after a few seconds (the default), or retained until manually dismissed. -
The
uibuildernode now has an extra tab "scripts" which lets you run npm scripts defined in your instance root's package.json file.These can be any script that can be run on the host OS. They run in the OS's default shell. Output from the script is captured and returned to Node-RED in the panel beneath the list of scripts. When a script is running, a "Kill Script" button is visible, clicking this wil abort the script immediately.
The
emoji is now in use consistently across UIBUILDER. You will find it in announcements on the forum, log messages, on the web page open buttons in the Editor and elsewhere. I am using this because emoji's are single-characters and usable anywhere that UTF-8 text is usable. -
uibuilder installation will now ERROR and stop if the Node-RED userDir folder is not writable. This is to prevent the uibuilder node from being misconfigured and not working correctly. The error message will show the userDir folder that is not writable.
When using uibuilder's custom web server option, you now have the option to create a
<uibRoot>/.publicfolder. It is served as the root URL. This is where you can place static files that you want to serve from the custom web server. The folder will be created automatically if it does not exist. You can also use this folder to serve static files such as images, CSS, and JavaScript files. Create anindex.htmlfile in the folder to serve a custom root home page. The folder is not served if you are using the default Node-RED web server (Use Node-RED's public folder for that). -
The documentation now has a "Tips" page that rotates through a selection of tips. I will be adding more tips over time. If you have any tips that you think would be useful, please let me know.
Example flows
- NEW
uib-basicAn inject node to a uibuilder node with debug nodes on each output. Inputs and outputs minimised. Outputs show full msg and show msg count. - UPDATED Client-side code > FE Router Test. A complete front-end router example flow including html, js and route partials.
- UPDATE "Remote Commands" renamed to "Control UI from Node-RED" and refreshed. New showOverlay notifications included.
uibuilder node
NEW Two new Editor actions have been added. This enables you to run these actions from keyboard shortcuts.
open-uibuilder-site- opens the selected uibuilder instances web site in a new browser tab.edit-uibuilder-site- opens the selected uibuilder instances source folder in your full IDE. THe configuration for this comes from the "Code Editor URL" in the node's advanced properties tab (defaulting to VS Code).
Updated the buttons on the Editor config panel's top button bar to use icons instead of text. Note that the wireframe globe is now used consistently across uibuilder.
NEW An extra tab "scripts" has been added. This lets you run npm scripts defined in your instance root's package.json file.
In addition to scripts that you define, the default npm
outdated,update, andinstallscripts are also available to run. -
FIX for issue #564. VSCode edit link would not work if the uibuilder root folder did not start with a
/. Also, the VSCode edit link could not be amended. -
FIX for duplicate url error when node is used in a subflow. Ref.
FIX for issue #556. The library list in the Editor config panel would not work correctly if a library name contained special characters. Thanks to Paul Reed for reporting this issue.
Ui class
Fixed a hidden issue with
replaceSlot(). The safe method of creating a DocumentFragment does not work if the parent element is a<template>. For that, you can only useinnerHTML. -
NEW showOverlay function. This function creates and displays an overlay window with customizable content and behavior. See the uibuilder client documentation for more details.
uib-sender node
- BUG FIX It was not returning messages from the front-end. This was a regression bug from a previous update. Many thanks to @Robert0 for reporting.
uib-brand.css front-end styles
- Improved colour contrast for default text/background.
- Improved background contrast for forms. Forms now stand out if emmbedded in an
<article>element. - Corrected the foreground/background colour for inputs and textareas. Now works better in light mode.
- Improved appearance of inputs and select elements outside of forms.
- Updated the table header styles to make them sticky. This means that the table headers will remain visible when scrolling down a long table. This is particularly useful for large tables with many rows.
- Changed
accent-colorto use the--primaryvariable rather than the--brandvariable.accent-coloris used by browsers to set the colour of form elements such as checkboxes and radio buttons. This means that the colour will now match the primary colour used in the rest of the uibuilder styles. - Added
cursor: pointer;to the<summary>element. This makes it clearer that the element is clickable and can be expanded or collapsed. - Improved
.status-side-panelstyles. Allowing background color to be overridden with--status-color.
For forms, the following CSS variables (show with their defaults) can be used to more easily change the appearance of the forms:
/* The main background color for form elements */
--form-bg: var(--surface1);
/* The main text color for form elements */
--form-fg: var(--text2);
/* The border color for form elements */
--form-border: 1px solid var(--text3);
For the updated navigation menus, the following CSS variables (show with their defaults) can be used to more easily change the appearance of the menus:
/* The main background color for the menu */
--nav-bg: var(--surface3);
/* The main text color for the menu */
--nav-fg: var(--text2);
/* Secondary background color - used when hovering over other menu items */
--nav-2nd-bg: var(--primary-bg);
/* More contrasting text color - used for selected menu items */
--nav-2nd-fg: var(--text1);
/* More contrasting background color - Used for menu pop-up background */
--nav-3rd-bg: var(--surface2);
uibuilder client library
NEW function
uibuilder.reactive(srcvar)This function allows you to create a reactive variable. It outputs a custom event when the variable changes (including deep object changes). It returns the reactive version of the variable. This also has several new methods:
onChange(property, callback): Adds a listener that triggers the callback when the specified property of the reactive variable changes. If'*'is specified, it listens for any change to the variable. It returns a reference to the callback that can be used to remove the listener later. The reference also has acancel()methodcancelChange(callbackRef): Removes a listener using a saved callback reference.
[!WARNING]
If the reactive variable is a primative type (string, number, boolean), then the you MUST use themyvar.value = 42syntax to change the value. If you usemyvar = 42, then the reactive variable will overwritten. Thevalueproperty will also let you change a primative even if it has been created withconst. -
NEW
showOverlayfunction. This function creates and displays an overlay window with customizable content and behavior. This is an easy way to display some temporary information to the user.Also available as an external (from Node-RED) command. In that case,
msg.payloadis used as the content of the overlay unlessoptions.contentis specified. Controlling options can be passed in themsg._uib.optionsproperty -
Updated the client library type description files. They are available in the
typesfolder of theblanktemplate. There is atsconfig.jsonfile in the root of that template that includes the type definitions. This means that you can now get better code completion, descriptions and type checking when using the client library in your own code. Feel free to copy the file and the folder to your own projects.[!WARNING]
The type definitions are not automatically updated when the client library is updated. You will need to update them manually by copying the files from UIBUILDER'stemplates/blank/src/front-end-modulefolder. -
Updated the
showDialogfunction:- Allow more flexible use. Any of the parameters can now be
nulland the function will use sensible defaults. That lets you simple calluibuilder.showDialog(null, null, msg)to get a notification that overlays the rest of the page and can be dismissed simply by clicking anywhere on the page. Note that the actual definition of the function resides in theui.jssource module. - Allow any keypress or touch to dismiss the dialog.
UI library source file renamed from
ui.jstoui.mjs. This is to make it clearer that it is an ES module. The file is still compiled into the client library as before. The gulp build process has been updated to reflect this change and simplified in line with the main client module build. -
UPDATED Full uibuilder intellisense is now available for VS Code users when editing front-end JavaScript. Update your JS files to include
/// <reference path="../types/uibuilder.d.ts" />at the start of your code. Don't forget to update thetypesfolder with updated type definitions after upgrading uibuilder. You may need to manually create thetypesfolder if using templates from previous versions. -
UPDATED The feature that allows external commands to be sent from Node-RED has been improved. It now supports additional options for customizing the command behavior. Currently only used by the new
showOverlaycommand. -
FIXED
uibuilder.formatNumber(...)- fixed handling of decimal places. Previously 0 dp was not working.
Added functions to auto-generate a menu of routes. Driven by updated router configuration data. Example:
{ defaultRoute: 'route01', routes: [ { id: 'theme', src: './fe-routes/theme-editor.html', type: 'url', title: 'Theme Editor', description: 'Theme editor.' }, { id: 'route01', src: './fe-routes/route01.html', type: 'url', title: 'Home Summary', description: 'A summary view of the home.' }, { id: 'wanted', src: './fe-routes/wanted.html', type: 'url', title: 'To Do', description: 'My to do list for this site.' }, ], routeMenus: [ { id: 'menu1', menuType: 'horizontal', label: 'Main Menu', }, ], }In this version, only horizontal, single-level menus are supported. In the future, expect to see multi-level and vertical menus. Possibly also tabbed menus. Search forms may also be added.
BUG FIX If you define the route container in the config but it does not exist, we now throw and error and stop. If you haven't defined a container at all, it is auto-created and attached to the body element and a warning issued.
Significantly improved documentation.
uibuilder configuration
- Updated the template middleware files that are copied to
<uibRoot>/.config/*.js-templateon each restart. Added links to uibuilder documentation and pointed out the use of the message and security hooks now available via the Node-RED settings.js file.
Documentation
NEW Quickstart guide completely rewritten. Now has two main approaches: no-code/low-code and low-code/custom code. Each approach has a step-by-step guide to get you started quickly.
Rearranged the sidebar for additional clarity.
NEW "Reactive UI's" in the client section. This is a new section that describes how to use the reactive attributes in UIBUILDER to create dynamic web pages with minimal code. It includes a summary of the available attributes and how to use them.
Updated
uib-configurationdocumentation to show the latest settings.js options including the msg, client and socket.io hooks. These allow you to enhance or override themsg._clientdata, simulate user authentication, block message send/receive, and redirect unauthenticated users. -
Updated the
security/authenticated-client-propertiesdocumentation. Added a tip about the hooks in the settings.js file. -
NEW Added a new "how-to" article describing how to use Node-RED and uibuilder as a live web development server. This is a simple way to get a live reload server without needing to use complex build tools.
Updated the comparison between uibuilder and Dashboard 2. Emphasising uibuilder's multi-app capabilities and dark mode.
Significantly improved uibRouter SPA documentation.
Updated walkthrough to match current templates. (Issue #563).
NEW Rotating "Tips" page added. Updates once per minute from a random selection of tips.
Main README updated with improved badges. Fixed the documentation badge, added a sponsor badge. A DeepWiki badge also added.
Comparison with Dashboard 2 updated to reflect current capabilities of both projects.
Some rework of the Docsify configuration.
- Added a "Tips" page that rotates through a selection of tips.
- Added a new tips custom Docsify plugin that allows display of tips from a given source folder. Used on the tips page. Provides rotating, random and specified tips.
- Removed the auto-restyleing of the word "UIBUILDER" that was using HTML colours. It was causing issues with some themes and was not accessible. I will add a manual
[UIBUILDER]Markdown extension that can be used when needed.
NEW Experimental front-end client library
NEW
../uibuilder/experimental.mjsexperimental front-end library. Internally loads the live client library and extends it with experimental features. It does require some setup and its features WILL change unexpectedly.Note that this library is only available as an ES Module.
src/front-end-module/experimental-demo.html- A simple demo page that shows how to use the experimental features. It is not intended for production use. You will need to copy the html file to a uibuilder instance'ssrcfolder and then load it in your browser. The demo page will show you how to use the experimental features. It may not always be up to date with the latest experimental features.
The purpose of this is to allow greater experimentation with new features without disturbing the live client library.
Development changes
- NEW file
src\front-end-module\reactive.mjs- contains the newReactiveclass that implements the reactive variable functionality. This is a new module that can be used in the front-end client library but can also be used independently. This is provided as source only for now. Though it is compiled into the client library as well and so available via theuibuilder.getReactiveClass()anduibuilder.reactive()functions. - uibuilder runtime library files renamed from *.js to *.cjs for clarity. Part of the long-term effort to move eventually to ES Modules.
- More code cleanup using latest ESLINT rules.
