Uibuilder with PostgreSQL connection
Dear sir, madam,
Is there a way to connect the uibuilder with the PostgreSQL database to call/ gather data, something similar to the code below here, without using the local flow connection (connecting the lines together)?
const { Client } = require('pg')
const client = new Client({
  user: 'sgpostgres',
  host: 'SG-PostgreNoSSL-14-pgsql-master.devservers.scalegrid.io',
  database: 'postgres',
  password: 'password',
  port: 5432,
client.connect(function(err) {
  if (err) throw err;
  console.log("Connected!");
That is not advisable. your credentials would be discoverable in the client side code.
You should either generate an API (add node-red endpoints) and call them from your pages OR use the built in mechanisms uibuilder gives you for passing data to/from node-red
alright, I see, thank you for your response/ answer.
