Hello, i am running nodered server on ibm cloud and unable to install smart-nora pallet. Earlier i was using google cloud successfully.
Welcome to the forum.
I had to google smart-nora... and once I realized your issue probably had nothing to do with a
"Proven snoring remedy"
I found your post on the contrib's git-hub page.
Unfortunately you didn't supply any more details there then you did here...
Author
gauravmyid commented 42 minutes ago
I have tried installing multiple times but still doesn't work
So, perhaps you can supply more details needed to assist?
Version of Node-Red? (I know nothing about the IBM Cloud aspect of it)
Do you have any logs from the palette install?
Or can you copy/paste the terminal text showing any attempted npm install?
On that note... Have you tried running the npm command from within node-red's directory? ~/.node-red or whatever equivalent it may be with the IBM Cloud version.
I tried installing it from pallet manager. It shows to check log and showed this "Failed to install: node-red-contrib-smartnora
Install failed
Check the log for more information:
when checked log details it shows following message
"2021-08-17T08:21:04.634Z Install : node-red-contrib-smartnora 1.1.3
2021-08-17T08:21:05.923Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix="~" --production node-red-contrib-smartnora@1.1.3
2021-08-17T08:21:12.574Z rc=null"
Is that the entire log?
Unfortunately yes.
Well, even though it is of no use to me, I installed it, via pallet, to test the process... and it took around 5 minutes!! But it did install. And then about a minute to uninstall!
So all I can suggest is try it again via npm and let it run until it says it did or didn't work.
Nothing else I can do.
