Hi
Anyone having this problem. Since Last week Apple Node in Nodered unable to log in using Apple id. Got this error message 401 - Not authorised.
Hi
A little more information would be helpful like
1 - the full name and version (you can get this by using the "Manage Palette" in the sidebar) of the node you are using
2 - what version of node-red and node.js (see the nr startup log)
3 - what version of macos are you running
4 - what device is NR running on and what OS and version is it using
5 - a copy of your flow
[EDIT: Note, If the node is node-red-contrib-apple-find-me, someone opened and issue on GitHub with the same issue five days ago. The author of the node is aware and thinks Apple may have made a change)
Yes its the node-red-contrib-apple-find-me issue
Your going to need to wait till the nodes author comes up with a solution ![]()
Uh the same problem on my side. First I thought there is something wrong on my side, but it is obvious there is a problem with a flow in connection with apple. I hope they will solve it.
