Hi, I have a strange issue I can't solve myself.
I'm was unable to upgrade node-red docker doing a pull so I've removed it and I've found I can't create a new one:
- Portainer says no such image:
- Meantime in the syslog:
Nov 3 12:29:09 tango dockerd-current: time="2023-11-03T12:29:09.667538307+01:00" level=error msg="Error trying v2 registry: unsupported schema version 2"
Nov 3 12:29:09 tango dockerd-current: time="2023-11-03T12:29:09.667575809+01:00" level=error msg="Attempting next endpoint for pull after error: unsupported schema version 2"
- Manual try:
[root@tango ~]# docker pull nodered/node-red:latest
Trying to pull repository docker.io/nodered/node-red ...
Using default tag: latest
Any other docker images seems to work (pulling helloworld, busybox, grafana, etc).
Any ideas?
