Unable to switch from Line to Bar Chart
Hi all,
can you please help me to switch from Line- to Bar-Chart ?
I have two msg.Objects msg1 and msg2 with individual topic and payloads.
If I insert them into a line-chart it works perfectly fine and I see two lines in the chart.
If I change chart type from line to bar all I see is one big bar, showing the last transfered value only :frowning:
No matter what I try ... I am unable to feed the bar chart in a reasonable way :frowning:
BR
Birdy
Try this flow
[{"id":"5d7328fa.5f3d5","type":"inject","z":"fe3f6423.a3e4c","name":"","topic":"a","payload":"35","payloadType":"num","repeat":"2","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":320,"wires":[["f0f9f267.4975b8"]]},{"id":"9d677079.daed68","type":"inject","z":"fe3f6423.a3e4c","name":"","topic":"b","payload":"50","payloadType":"num","repeat":"2","crontab":"","once":false,"onceDelay":0.1,"x":170,"y":400,"wires":[["f0f9f267.4975b8"]]},{"id":"891aa3ec.c15188","type":"ui_chart","z":"fe3f6423.a3e4c","name":"","group":"dd49e86.e03cc98","order":2,"width":0,"height":0,"label":"chart","chartType":"bar","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":530,"y":360,"wires":[[]]},{"id":"f0f9f267.4975b8","type":"random","z":"fe3f6423.a3e4c","name":"","low":"1","high":"20","inte":"true","property":"payload","x":340,"y":360,"wires":[["891aa3ec.c15188"]]},{"id":"dd49e86.e03cc98","type":"ui_group","z":"","name":"Default","tab":"a964f67f.642008","disp":true,"width":"6","collapse":false},{"id":"a964f67f.642008","type":"ui_tab","z":"","name":"Home","icon":"dashboard","disabled":false,"hidden":false}]
Oh, yes, this works perfectly fine ! Thanks a lot for your support !
