Unexpected Node Error. node-red-contrib-tplink. Error: read ECONNRESET
Within the Node-RED GUI, I'm getting a message in my debug window.
It is intermittent.
I'm pretty new to Node-RED.
I can't seem to use the Catch node to catch it.
I'm not able to use the Status node to do anything with it.
  1. Is there a way to prevent this from going to the debug window?
  2. Do you have any recommendations on how to troubleshoot the source of the problem?
FYI, separately, I posted a question about which KASA nodes I should be using in case there's a better choice out there: Recommendation for TP-Link Kasa Smart Wi-Fi Devices
msg : string[481]
Info:
Node object is not a node-red Node
Stack:
at TCP.onStreamRead (node:internal/stream_base_commons:217:20)
Please report this issue, including the information logged above:
