Yes, the folder mentioned exist ...
For information, in the node red setting.js I have:
. change uiPort
. set a httpStatic
. set adminAuth with username and password
. set httpNodeAuth with username and password
My project works for a few months without big problems excluded object detection with tfjs-coco-ssd after update to the new version (palette) don't work ...
This is the log:
pi@raspberrypi:~ $ node-red
29 Nov 11:41:09 - [info]
Welcome to Node-RED
29 Nov 11:41:09 - [info] Node-RED version: v1.3.4
29 Nov 11:41:09 - [info] Node.js  version: v12.22.0
29 Nov 11:41:09 - [info] Linux 5.10.63-v7l+ arm LE
29 Nov 11:41:09 - [info] Loading palette nodes
SmartthingsConfigNode
29 Nov 11:41:14 - [info] Dashboard version 3.1.2 started at /ui
29 Nov 11:41:15 - [info] Settings file  : /home/pi/.node-red/settings.js
29 Nov 11:41:15 - [info] HTTP Static    : /home/pi/imgcam
29 Nov 11:41:15 - [info] Context store  : 'default' [module=memory]
29 Nov 11:41:15 - [info] User directory : /home/pi/.node-red
29 Nov 11:41:15 - [warn] Projects disabled : editorTheme.projects.enabled=false
29 Nov 11:41:15 - [info] Flows file     : /home/pi/.node-red/flows_raspberrypi.json
(node:21636) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, scandir '/usr/lib/node_modules/node-red/node_modules/@node-red/nodes/examples'
(node:21636) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
(node:21636) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
29 Nov 11:41:15 - [info] Server now running at http://127.0.0.1:1968/admin/
your credentials.
29 Nov 11:41:16 - [info] Starting flows
  type: 'smartthings-config',
  token: '9fccaea8-a4f9-475a-8dd3-e73f8bc32ae4',
  _users: [
    '9376f12d.2f3d5',
    '4c9fb70e.8e7738',
    '785b68e3.e42738',
    'd8485848.f1c9f8',
    '627df546.e67e84',
    '3f1abca.9f608c4',
    '41d43139.c912b',
    '6a8a9c0a.e357ac'
SmartthingsConfigNode called
SmartthingsButtonNode
SmartthingsOnOffNode
  type: 'smartthings-node-onoff',
  z: '449216f2.c5187',
  conf: 'ba51a982.2707b8',
  name: 'Vimar Switch 01',
  device: 'f8c9731c-ad60-43b6-8a9d-e88070e32d18',
  x: 1550,
  y: 1220,
  wires: [ [ '8d540987.c56ac8' ] ]
getDeviceStatus:token:9fccaea8-a4f9-475a-8dd3-e73f8bc32ae4
Request::
url:     https://api.smartthings.com/v1/devices/f8c9731c-ad60-43b6-8a9d-e88070e32d18/components/main/capabilities/switch/status
method:  GET
json:    true
headers:
  Authorization: Bearer 9fccaea8-a4f9-475a-8dd3-e73f8bc32ae4
qs:
body:
SmartthingsMotionNode
  type: 'smartthings-node-motion',
  z: '348ee176.f8584e',
  name: 'Aeotec Multisensor',
  device: '1d922164-ddfa-47c2-bb57-71355d892794',
  x: 110,
  y: 740,
  wires: [ [ '2f1c9388.36a54c' ] ]
Request::
url:     https://api.smartthings.com/v1/devices/1d922164-ddfa-47c2-bb57-71355d892794/components/main/capabilities/motionSensor/status
method:  GET
json:    true
headers:
qs:
body:
Platform node has already been set. Overwriting the platform with [object Object].
29 Nov 11:41:17 - [error] [tensorflowCoco:8779f7a.f0b0388] TypeError: Cannot read property 'whereImpl' of undefined
  z: '545b2d85.6c6f64',
  name: 'Aeotec Outlet A',
  device: '4b408ac3-33fb-4e89-ad1a-430d3b570b9c',
  x: 180,
  y: 1140,
  wires: [ [ '559279e6.6028c8' ] ]
Request::
url:     https://api.smartthings.com/v1/devices/4b408ac3-33fb-4e89-ad1a-430d3b570b9c/components/main/capabilities/switch/status
method:  GET
json:    true
headers:
qs:
body:
  name: 'Aeotec Outlet L',
  device: 'daeb89ed-dd8a-47a6-b5ba-2e84e5dc1a87',
  x: 180,
  y: 1400,
  wires: [ [ 'fb76cf9e.0a114' ] ]
Request::
url:     https://api.smartthings.com/v1/devices/daeb89ed-dd8a-47a6-b5ba-2e84e5dc1a87/components/main/capabilities/switch/status
method:  GET
json:    true
headers:
qs:
body:
  name: 'Frient Plug smart 2',
  device: '65547a82-4cfa-45a7-a456-ff92d4ce4dbe',
  x: 190,
  y: 420,
  wires: [ [ '767a0f3f.bce6c' ] ]
Request::
url:     https://api.smartthings.com/v1/devices/65547a82-4cfa-45a7-a456-ff92d4ce4dbe/components/main/capabilities/switch/status
method:  GET
json:    true
headers:
qs:
body:
  name: 'Frient Plug smart',
  device: '79d3a792-df0a-4ace-8874-c2da54e06d35',
  x: 190,
  y: 900,
  wires: [ [ '71bbdc04.73132c' ] ]
Request::
url:     https://api.smartthings.com/v1/devices/79d3a792-df0a-4ace-8874-c2da54e06d35/components/main/capabilities/switch/status
method:  GET
json:    true
headers:
qs:
body:
29 Nov 11:41:18 - [info] Started flows
29 Nov 11:41:19 - [info] [mqtt-broker:MyMQTT] Connected to broker: mqtt://localhost:1883
29 Nov 11:41:19 - [info] [alexa-remote-account:MyAlexa] intialising "MyAlexa" with the PROXY method and saved data...
29 Nov 11:41:19 - [info] [deconz-server:Phoscon] WebSocket opened
Device Status (daeb89ed-dd8a-47a6-b5ba-2e84e5dc1a87):
{ switch: { value: 'off', timestamp: '2021-11-29T06:52:58.381Z' } }
Device Status (4b408ac3-33fb-4e89-ad1a-430d3b570b9c):
{ switch: { value: 'off', timestamp: '2021-11-29T08:33:59.017Z' } }
Device Status (f8c9731c-ad60-43b6-8a9d-e88070e32d18):
{ switch: { value: 'off', timestamp: '2021-11-28T12:39:09.856Z' } }
Device Status (1d922164-ddfa-47c2-bb57-71355d892794):
  motion: { value: 'inactive', timestamp: '2021-11-29T09:28:21.609Z' }
OnOffDevice(Aeotec Outlet L) Status Refreshed
OnOffDevice(Aeotec Outlet A) Status Refreshed
OnOffDevice(Vimar Switch 01) Status Refreshed
MotionDevice(Aeotec Multisensor) Status Refreshed
Device Status (79d3a792-df0a-4ace-8874-c2da54e06d35):
{ switch: { value: 'off', timestamp: '2021-11-22T12:25:16.449Z' } }
Device Status (65547a82-4cfa-45a7-a456-ff92d4ce4dbe):
{ switch: { value: 'off', timestamp: '2021-11-22T08:09:52.166Z' } }
OnOffDevice(Frient Plug smart) Status Refreshed
OnOffDevice(Frient Plug smart 2) Status Refreshed
29 Nov 11:41:22 - [info] [alexa-remote-account:MyAlexa] intialising "MyAlexa" with the PROXY method and saved data...
29 Nov 11:41:25 - [error] [alexa-remote-account:MyAlexa] Initialisation was aborted!
29 Nov 11:41:48 - [info] [alexa-remote-account:MyAlexa] intialising "MyAlexa" with the PROXY method and saved data...
