Unit testing configuration node
Is it possible to unit test config nodes in isolation? If so, how do I go about doing it?
I am also interested in this. What I've tried so far was not successful.
  1. I manually tested that I can create and connect to a remote host with the config node so I know it works.
  2. I then tried to write a unit test that proves that the config node is loaded by checking that one of it's properties exists.
  3. The test failed.
    it('should be loaded', (done) => {
        var flow = [{ id: "n1", type: "qsys-core", host: "127.0.0.1" }];
        helper.load(qsysCore, flow, () => {
            var n1 = helper.getNode("n1");
            try {
                n1.should.have.property('host', '127.0.0.1');
                done();
            } catch (err) {
                done(err);
Caveat: There are surely people with more experience with this sort of thing than I on the forum. My failed unit test may be the result of some silly typo or missed declaration that I haven't yet tracked down.
