Unknown node type "uc-iodataIn" and "uc-iodataOut"
I am with a project in which there are some unknown nodes, "uc-iodataIn" and "uc-iodataOut", could someone tell me what library I have to use to make them work?
You really need to provide more information, remember no one but you can see what you are doing.
Did you try a google search using uc-iodataIn?
If so, what results did you find? If not, why not?
Those maybe nodes provided by the hardware manufacturer, so you may need to contact them.
I tried a google search and found only a Python library.
But there is a mention of uc-iodataIn in a post from Dec 2021 Extracting data from an array
If the poster, @Bastian is still around, maybe he can advise you.
There is also a flow example
https://flows.nodered.org/flow/a22d74d343f30807d82630bff2856a58
but it doesn't explain what the name of the node is or where to get it.
Hi there.
The Node-RED environment of a company called WeidmĂĽller uses similar customized iodata-in and iodata-out nodes on their automation control.
Checking for uc-iodata nodes I get the following:
They are used to transfer data from the real time system of the automation control to the Node-RED instance which is running on a second non-realtime instance. Those nodes don't seem to make sense without the WeidmĂĽller hardware.
Regards
