Updating location in WorldMap using Speed Slider
I have been working on a project where I am designing a flight control system to control UAV. So far, I have been able to initialize Lat/Lon values from user and update the icon in the Map and move the icon with buttons to N,S,E,W directions. My main concern is how can I update/move the icon to next location using a slider which gradually makes the icon move to next location?
The formulas for calculation the next position are already implemented in the function node but I have been stuck in this project for about a month. If anyone can help me out, it would be great.
Here is my current flow:
        "id": "594f4d4bfd9f7699",
        "type": "tab",
        "label": "Flight_Control_SIMULU",
        "disabled": false,
        "info": "",
        "env": []
        "id": "319ff3a15befbaa7",
        "type": "ui_worldmap",
        "z": "594f4d4bfd9f7699",
        "group": "b4ebae93d455bbc5",
        "order": 1,
        "width": 9,
        "height": 10,
        "lat": "48.80",
        "lon": "13.50",
        "zoom": "",
        "layer": "OSMC",
        "cluster": "0",
        "maxage": "",
        "usermenu": "hide",
        "layers": "hide",
        "panit": "true",
        "panlock": "false",
        "zoomlock": "false",
        "hiderightclick": "true",
        "coords": "deg",
        "showgrid": "false",
        "showruler": "false",
        "allowFileDrop": "false",
        "path": "/worldmap",
        "overlist": "DR,CO,RA,DN,AC,HM",
        "maplist": "OSMG,OSMC,EsriC,EsriS,EsriT,EsriDG,UKOS",
        "mapname": "",
        "mapurl": "",
        "mapopt": "",
        "mapwms": false,
        "x": 1100,
        "y": 40,
        "id": "01732bfeeaa6afce",
        "type": "ui_text_input",
        "label": "Initial Lat Position",
        "tooltip": "",
        "order": 2,
        "width": 6,
        "height": 1,
        "passthru": true,
        "mode": "number",
        "delay": "100",
        "topic": "lat",
        "sendOnBlur": true,
        "className": "",
        "topicType": "str",
        "x": 150,
        "y": 160,
                "fa8d16f8a3e226de"
        "id": "2aeed1b10c6c1515",
        "type": "ui_button",
        "order": 3,
        "width": 2,
        "height": 1,
        "passthru": false,
        "label": "Set",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "payload": "",
        "payloadType": "str",
        "topic": "set",
        "topicType": "str",
        "x": 330,
        "y": 40,
                "fa8d16f8a3e226de"
        "id": "2cb3acd121995f56",
        "type": "worldmap-tracks",
        "depth": 20,
        "layer": "single",
        "smooth": false,
        "x": 710,
        "y": 140,
                "14927396080798d3"
        "id": "14927396080798d3",
        "type": "worldmap",
        "lat": "48.80",
        "lon": "13.50",
        "zoom": "",
        "layer": "OSMC",
        "cluster": "",
        "maxage": "20",
        "usermenu": "show",
        "layers": "show",
        "panit": "true",
        "panlock": "false",
        "hiderightclick": "false",
        "coords": "deg",
        "mapname": "",
        "mapurl": "",
        "mapopt": "",
        "mapwms": false,
        "x": 940,
        "y": 200,
        "id": "3f1eed7c26c68aa2",
        "label": "Initial Lon Position",
        "tooltip": "",
        "order": 4,
        "width": 6,
        "height": 1,
        "passthru": true,
        "mode": "number",
        "delay": "100",
        "topic": "lon",
        "sendOnBlur": true,
        "className": "",
        "topicType": "str",
        "x": 150,
        "y": 200,
                "fa8d16f8a3e226de"
        "id": "bd958146f73af5c1",
        "order": 12,
        "width": 6,
        "height": 1,
        "passthru": false,
        "label": "up",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "payload": "",
        "topic": "up",
        "topicType": "str",
        "x": 130,
        "y": 60,
                "fa8d16f8a3e226de"
        "id": "83cee2bda843d0d2",
        "order": 14,
        "width": 6,
        "height": 1,
        "passthru": false,
        "label": "down",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "payload": "",
        "topic": "down",
        "topicType": "str",
        "x": 110,
        "y": 260,
                "fa8d16f8a3e226de"
        "id": "03aa2f6ba41795a5",
        "order": 16,
        "width": 6,
        "height": 1,
        "passthru": false,
        "label": "left",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "payload": "",
        "topic": "left",
        "topicType": "str",
        "x": 110,
        "y": 300,
                "fa8d16f8a3e226de"
        "id": "7347a00f5de4aab0",
        "order": 18,
        "width": 6,
        "height": 1,
        "passthru": false,
        "label": "right",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "payload": "",
        "topic": "right",
        "topicType": "str",
        "x": 130,
        "y": 120,
                "fa8d16f8a3e226de"
        "id": "fa8d16f8a3e226de",
        "type": "function",
        "name": "function 3",
        "func": "var R = 6378.1; // Radius of Earth\nvar dist = 100; // Distance in meters\nvar theta = (dist / R) * 2 * Math.PI; // Angular distance in radians\nvar speed = 0;\n\nvar lat1 = 0.0;\nvar lon1 = 0.0;\n\nvar lat2 = flow.get(\"lat2\") || 0; //Set Initial Latitude Position\nvar lon2 = flow.get(\"lon2\") || 0; //Set Initial Longitude Position\n\nif(msg.topic == \"lat\"){\n    lat2 = msg.payload; \n    flow.set(\"lat2\", lat2);\n    \n}\n\nif(msg.topic == \"lon\"){\n    lon2 = msg.payload ;\n    flow.set(\"lon2\", lon2);\n    \n}\n\n//Calculate Bearing for Direction\nvar y = Math.sin(lon2 - lon1) * Math.cos(lat2);\nvar x = Math.cos(lat1)*Math.sin(lat2) - Math.sin(lat1)*Math.cos(lat2)*Math.cos(lon2-lon1);\nvar angle = Math.atan2(y, x);\nvar brng = (angle*180/Math.PI + 360) % 360; // in degrees\n\n//Set Position using Set Button\nif(msg.topic == \"set\"){\n    var set_it = {\n        name:\"SIMULU\",\n        lat: lat2,\n        lon: lon2,\n        icon: \"plane\",\n        iconColor: \"black\",\n        layer: \"gps\",\n        bearing: brng,\n        speed: speed + \"kn\",\n        popped: true\n    }\n    msg.payload = set_it;\n}\n\n//Calculation for next point\nvar lat3 = Math.asin(Math.sin(lat1) * Math.cos(theta) +\n            Math.cos(lat1) * Math.sin(theta) * Math.cos(brng));\n\nvar lon3 = lon1 + Math.atan2(Math.sin(brng) * Math.sin(theta)* Math.cos(lat1),\n            Math.cos(theta) - Math.sin(lat1) * Math.sin(lat3))\n\nvar lat3_deg = lat3 * 180 / Math.PI;\nvar lon3_deg = lon3 * 180 / Math.PI;\n\n//Calculation of bearing for next point\nvar y_1 = Math.sin(lon3 - lon2) * Math.cos(lat3);\nvar x_1 = Math.cos(lat2) * Math.sin(lat3) - Math.sin(lat2) * Math.cos(lat3) * Math.cos(lon3 - lon2);\nvar angle = Math.atan2(y_1, x_1);\nvar brng_1 = (angle * 180 / Math.PI + 360) % 360; // in degrees\n\n//Speed slider for next point\nif(msg.topic == \"speed\"){\n    var nxt_pnt = {\n        name: \"SIMULU\",\n        lat: lat3_deg,\n        lon: lon3_deg,\n        bearing: brng_1,\n        layer: \"gps\",\n        popped: true\n    }\n    msg.payload = nxt_pnt;\n}\n\n//Control Buttons for directions\nlet move = flow.get(\"location\") || set_it;\nlet bearing = move.bearing;\nlet lat = move.lat;\nlet lon = move.lon;\n\nif(msg.topic == \"up\"){\n    if(bearing = 0){\n        bearing = 0;\n    }\n    move.lat = move.lat + 0.01;\n    move.lon = move.lon + 0; \n    var up = {\n        name:\"SIMULU\",\n        lat: move.lat,\n        lon: move.lon,\n        bearing:bearing,\n        layer:\"gps\",\n        popped:true\n    }\n    node.warn(\"Up-bearing=\" +bearing);\n    msg.payload = up;\n}\n\nif(msg.topic==\"right\"){\n    if(bearing >= 0 || bearing < 90){\n        bearing = 90;\n    }\n    move.lat = move.lat + 0;\n    move.lon = move.lon + 0.01;\n    var right = {\n        name:\"SIMULU\",\n        lat: move.lat,\n        lon: move.lon,\n        bearing:bearing,\n        layer:\"gps\",\n        popped:true\n    }\n    node.warn(\"Right-bearing=\" +bearing)\n    msg.payload = right;\n}\n\nif(msg.topic == \"down\"){\n    if(bearing > 90 || bearing < 270){\n        bearing = 180;\n    }\n    move.lat = move.lat - 0.01;\n    move.lon = move.lon  - 0;\n    var down = {\n        name: \"SIMULU\",\n        lat: move.lat,\n        lon: move.lon,\n        bearing:bearing,\n        layer:\"gps\",\n        popped:true\n    }\n    node.warn(\"Down-bearing=\" +bearing)\n    msg.payload = down;\n}\n\nif(msg.topic==\"left\"){\n    if(bearing > 180 || bearing < 360 ){\n        bearing = 270;\n    }\n    move.lat = move.lat - 0;\n    move.lon = move.lon - 0.01;\n    var left = {\n        name:\"SIMULU\",\n        lat: move.lat,\n        lon: move.lon,\n        bearing:bearing,\n        layer:\"gps\",\n        popped:true\n    }\n    node.warn(\"Left-bearing=\" +bearing)\n    msg.payload = left;\n}\n\nmove.bearing = bearing;\nflow.set(\"location\", move);\n//msg.payload = move;\n\n/*let new_location = flow.get(\"new_location\") || move;\nlet new_lat = new_location.lat;\nlet new_lon = new_location.lon;\n\n\nif(msg.topic == \"set\"){\n    flow.set(\"new_location\", new_location);\n    node.warn(\"new_location:\" +new_location);\n    msg.payload = new_location;\n}\n*/\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 500,
        "y": 160,
                "9336120dc02d8212",
                "2cb3acd121995f56",
                "14927396080798d3"
        "id": "9336120dc02d8212",
        "type": "debug",
        "name": "debug 4",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 800,
        "y": 320,
        "id": "4293d65595438ef9",
        "type": "ui_slider",
        "label": "Speed",
        "tooltip": "",
        "order": 10,
        "width": 6,
        "height": 1,
        "passthru": true,
        "outs": "end",
        "topic": "speed",
        "topicType": "str",
        "min": 0,
        "max": "100",
        "step": "0.1",
        "className": "",
        "x": 110,
        "y": 360,
        "id": "b4ebae93d455bbc5",
        "type": "ui_group",
        "name": "UAV Flight Control",
        "tab": "37a720198b072daf",
        "order": 1,
        "disp": true,
        "width": "17",
        "collapse": false,
        "className": ""
        "id": "37a720198b072daf",
        "type": "ui_tab",
        "name": "Flight_Control",
        "icon": "dashboard",
        "order": 2,
        "disabled": false,
        "hidden": false
