Upgrade node red to 4.3.1
Hi, I can install node-red-dashboard, and was ask to upgrade to 4.3.1 ?
How to do it, Please help.
William Fu
There is no such version. Can you post the exact message you are getting please?
Edit: also tell us what hardware/OS you are running on and how you installed node-red.
My guess is that it asks to upgrade Node JS version to 4.3.1 and later, not Node Red.
If you uses Raspberry pi, then you can simply use the script to upgrade Node Red and Node JS to the latest version.
https://nodered.org/docs/getting-started/raspberrypi
I able to solve it
