did it. Looks like I have some research to do. oh well...
npm ERR! code 1
npm ERR! path /home/pi/.node-red/node_modules/ncd-red-comm/node_modules/@serialport/bindings
npm ERR! command failed
npm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
npm ERR! make: Entering directory '/home/pi/.node-red/node_modules/ncd-red-comm/node_modules/@serialport/bindings/build'
npm ERR! CXX(target) Release/obj.target/bindings/src/serialport.o
npm ERR! make: Leaving directory '/home/pi/.node-red/node_modules/ncd-red-comm/node_modules/@serialport/bindings/build'
npm ERR! prebuild-install WARN install No prebuilt binaries found (target=16.13.0 runtime=node arch=arm libc= platform=linux)
npm ERR! gyp info it worked if it ends with ok
npm ERR! gyp info using node-gyp@3.4.0
npm ERR! gyp info using node@16.13.0 | linux | arm
npm ERR! (node:872) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
npm ERR! gyp info spawn /usr/bin/python2
npm ERR! gyp info spawn args [
npm ERR! gyp info spawn args '/home/pi/.node-red/node_modules/node-gyp/gyp/gyp_main.py',
npm ERR! gyp info spawn args 'binding.gyp',
npm ERR! gyp info spawn args '-f',
npm ERR! gyp info spawn args 'make',
npm ERR! gyp info spawn args '-I',
npm ERR! gyp info spawn args '/home/pi/.node-red/node_modules/ncd-red-comm/node_modules/@serialport/bindings/build/config.gypi',
npm ERR! gyp info spawn args '/home/pi/.node-red/node_modules/node-gyp/addon.gypi',
npm ERR! gyp info spawn args '/home/pi/.node-gyp/16.13.0/include/node/common.gypi',
npm ERR! gyp info spawn args '-Dlibrary=shared_library',
npm ERR! gyp info spawn args '-Dvisibility=default',
npm ERR! gyp info spawn args '-Dnode_root_dir=/home/pi/.node-gyp/16.13.0',
npm ERR! gyp info spawn args '-Dnode_gyp_dir=/home/pi/.node-red/node_modules/node-gyp',
npm ERR! gyp info spawn args '-Dnode_lib_file=node.lib',
npm ERR! gyp info spawn args '-Dmodule_root_dir=/home/pi/.node-red/node_modules/ncd-red-comm/node_modules/@serialport/bindings',
npm ERR! gyp info spawn args '--depth=.',
npm ERR! gyp info spawn args '--no-parallel',
npm ERR! gyp info spawn args '--generator-output',
npm ERR! gyp info spawn args 'build',
npm ERR! gyp info spawn args '-Goutput_dir=.'
npm ERR! gyp info spawn args ]
npm ERR! gyp info spawn make
npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:
npm ERR! ../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
npm ERR! ^~~~~~~~~~~~~
npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:
npm ERR! ../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
npm ERR! ^~~~~~~~~~~~~~~
npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:
npm ERR! ../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:
npm ERR! ../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:
npm ERR! ../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:
npm ERR! ../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
npm ERR! ../src/serialport.cpp:329:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
npm ERR! results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
npm ERR! ^
npm ERR! In file included from /home/pi/.node-gyp/16.13.0/include/node/node.h:63,
npm ERR! from ../../../../../nan/nan.h:58,
npm ERR! from ../src/./serialport.h:6,
npm ERR! from ../src/serialport.cpp:1:
npm ERR! /home/pi/.node-gyp/16.13.0/include/node/v8.h:3961:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)’
npm ERR! V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,
npm ERR! ^~~
npm ERR! /home/pi/.node-gyp/16.13.0/include/node/v8.h:3961:37: note: candidate expects 3 arguments, 2 provided
npm ERR! /home/pi/.node-gyp/16.13.0/include/node/v8.h:3964:37: note: candidate: ‘v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)’
npm ERR! V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
npm ERR! ^~~
npm ERR! /home/pi/.node-gyp/16.13.0/include/node/v8.h:3964:37: note: candidate expects 3 arguments, 2 provided
npm ERR! ../src/serialport.cpp:330:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
npm ERR! results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
npm ERR! ^
npm ERR! ^~~
npm ERR! ^~~
npm ERR! ../src/serialport.cpp:331:96: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)’
npm ERR! results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
npm ERR! ^
npm ERR! ^~~
npm ERR! ^~~
npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:
npm ERR! ../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
npm ERR! uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
npm ERR! ^~~~~~~~~~~~~~~~~~~~
npm ERR! ../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
npm ERR! ../src/serialport.cpp:378:106: error: no matching function for call to ‘v8::Object::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)’
npm ERR! results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
npm ERR! ^
npm ERR! ^~~
npm ERR! ^~~
npm ERR! ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:
npm ERR! ../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
npm ERR! uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
npm ERR! ../src/serialport.cpp: At global scope:
npm ERR! ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses]
npm ERR! SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
npm ERR! ^
npm ERR! ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses]
npm ERR! SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
npm ERR! ^
npm ERR! In file included from ../../../../../nan/nan.h:58,
npm ERR! /home/pi/.node-gyp/16.13.0/include/node/node.h:821:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
npm ERR! (node::addon_register_func) (regfunc), \
npm ERR! ^
npm ERR! /home/pi/.node-gyp/16.13.0/include/node/node.h:855:3: note: in expansion of macro ‘NODE_MODULE_X’
npm ERR! NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
npm ERR! ../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’
npm ERR! NODE_MODULE(serialport, init);
npm ERR! make: *** [bindings.target.mk:108: Release/obj.target/bindings/src/serialport.o] Error 1
npm ERR! gyp ERR! build error
npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
npm ERR! gyp ERR! stack at ChildProcess.onExit (/home/pi/.node-red/node_modules/node-gyp/lib/build.js:276:23)
npm ERR! gyp ERR! stack at ChildProcess.emit (node:events:390:28)
npm ERR! gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:290:12)
npm ERR! gyp ERR! System Linux 5.10.63-v7l+
npm ERR! gyp ERR! command "/usr/bin/node" "/home/pi/.node-red/node_modules/.bin/node-gyp" "rebuild"
npm ERR! gyp ERR! cwd /home/pi/.node-red/node_modules/ncd-red-comm/node_modules/@serialport/bindings
npm ERR! gyp ERR! node -v v16.13.0
npm ERR! gyp ERR! node-gyp -v v3.4.0
npm ERR! gyp ERR! not ok
npm ERR! /home/pi/.npm/_logs/2021-11-02T21_22_06_028Z-debug.log
