Is this the right command for Upgrading node.js and node-red for AWS EC2 ubuntu:
I can't find the explanation in the documentation
That may depend on how you installed it. How did you do that?
Also what does
node -v
show, and which version of node-red are you currently on?
First:
sudo apt update
sudo apt -y upgrade
To install NodeJS:
curl -sL https://deb.nodesource.com/setup_14.x | sudo -E bash -
sudo apt-get install -y nodejs
To update NodeJS:
sudo n stable
To install the latest release, use sudo n latest
Alternatively, you can run sudo n #.#.# to get a specific Node version.
To install/update NodeRed:
sudo npm install -g --unsafe-perm node-red
