Use (2) i2c lcd 1602
Hello everyone. Thanks for the acceptance in the forum. I have 2 i2c lcds with address 0x26 and 0x27. I can't find any nodes to control separately. Can you give me a solution please. Thanks in advance.
Make, model, link to site that sells the same I2c device you have? There are many different kinds of I2C lcd's
i2c Lcd
Lets try again.
I asked for:
You posted a picture. This is not helpful as it did not address any of the above asked for information.
I have wrote a node for working with LCD's
I'm not going to take the time to treasure hunt the image/picture to see if I can help you.
See above link and check that your device is driven by a I2c to MCP23017, if not, best of luck.
there's not a lot of information on it. I had already tested with your node. no result. I found PCF8574 on it. THANKS
A little google search brought me to this:
and it has a lot of information about the board.
A search on the flows tab of the forum, using pcf8574, finds an number of nodes you can try out.
THANKS. I would go see the site.
