I have a problem with a function in node-red. I want to read an object of the instance spotify-premium. The problem is the hyphen in the name.
The path I would like to read is:
For your own created properties it is just easier to avoid hyphens, but if incoming data is not under your control you have option to use bracket notation
If in doubt about how to reference something send it to a debug node then one of the little buttons that appears when you hover over it, when clicked, will copy the path, which you can paste somewhere and look at.
I did suspect that but I typically (or rather untypically ) tend to not use the likes of change nodes and more so use function nodes. But I do appreciate why.
