Use Echo Dot for NR voice commands?
Hiho,
is it possible to use an Echo Dot (5. Gen) as speech control for my Node Rede devices ?
There are many nodes for integrating with Alexa, from adding virtual devices and sending commands etc, at the node library. Library - Node-RED
Whether they work with Gen 5 is something you will need to check by reading help text or trying them.
I would personally recommend starting off with @hardillb Alexa eco-system
https://alexa-node-red.bm.hardill.me.uk/docs
as it's the most reliable one I use
If you need more flexibility then try out node-red-contib-remote-applestrudel but be warned that it's unreliable at times
Or node-red-contrib-alexa-smart-home which appears to be a fork of hardill's node (also works with Google Home)
