I am new with node-red.
My project involve a sensor connect with RevPi.
My objective is to read sensor data from node-red.
I have install node-red
From those video, I have to install this "node-red-contrib-revpi-nodes"
Video:
a. Revolution Pi and Node-RED Tutorial, Part 1, Youtube
b. Revolution Pi and Node-RED RevPi Nodes Tutorial, Part 2, Youtube
"Revolution Pi und Node-RED RevPi Nodes Tutorial, Teil 2 - YouTube"
on cmd, I type npm install node-red-contrib-revpi-nodes
Then , on my node-red local, I also had install at "Manage Palette" > Install > node-red-contrib-revpi-nodes
Revolution nodes, successfully install.
When I drag pin core and I want to put the value of the Pin, there none.
I assume, I wrongly do because the video is using raspberry pi and i am using window 10?
Or is it because i did not connect my revpi to laptop?
Ouh, thank you for the info.
Do you have any webpage or video on how to configure flow revpi with node-red ?
I cannot found any video on how to configure.
I found a web page: How to create a Node Red application - Industrial Raspberry Pi
but I still cannot understand the flow.
I don't know, but if it runs a debian based os (which I think it does) then I would start by trying the Pi script Running on Raspberry Pi : Node-RED
I assume you are a beginner with node red so I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot in about 1 hour. A small investment for a lot of gain.
