Using a digital input to ramp up
Hey I have a question about a ramp up i'm trying to create.
case : I have a speedcontroller -10 to +10V regulated. i want to use a potmeter to set the nominal speed. (value X) but before reaching that value, I would like a ramp up and ramp down set with a time value (time to nominal speed).
I found a "ease" node, that contains all the fancy ramps i need, but having a digital pin start a ramp up, nominal -> until the Digital Pin changes to false and then ramp down.
curious if this is possible!
There are digital potentiometers that may help. Without offering anything specific if you use one of those you could hit it with a PWM or a climbing and descending digital number to vary resistance depending on which digipot you use. I can see a fairly simple function node there but there may be better nodes available.
Do you want a set time or a fixed ramp rate?
A fixed ramp rate to a value is easier.
it's over time.
but i found the functionality of the ease node, this works well, only that i need to be able to set the parameter without it starting :slight_smile:
now when i throw a JSON at it to set the values, it start directly.
am i correct assuming I need to start it always with a json?
That is a pity as I have a flow that you can send a value to and it will go from the current value to the new value at a defined rate, then you can send it another value and it will ramp to that one.
I don't know anything about that node.
