Hello
I'm trying to use this library in a function node: aws-s3-multipart-copy - npm
I have installed the requirements, AWS credentials are ok, and I'm using the below code in my function node which is based on the sample code:
let logger = bunyan.createLogger({
level: 'info',
version: '1.0.0',
logType: 'copy-object-multipart-log',
serializers: { err: bunyan.stdSerializers.err }
let s3 = new AWS.S3();
s3Module.init(s3, logger);
let request_context = 'request_context';
let options = {
source_bucket: 'mybucket',
object_key: 'tmp/VID_20240320_175855.mp4',
destination_bucket: 'mybucket',
copied_object_name: 'tmp/test.mp4',
object_size: 7388415,
copy_part_size_bytes: 5000000,
copied_object_permissions: 'bucket-owner-full-control',
expiration_period: 100000,
storage_class: 'STANDARD'
s3Module.copyObjectMultipart(options, request_context)
.then((result) => {
console.log(result);
msg.payload = result
.catch((err) => {
// handle error
return null;
The good thing : it's working fine, the copy is performed.
However, I was expecting that on completion of the copy the code part in the then would be executed and the flow could go on with the message.
But it doesn't ![]()
As my Javascript skills are quite basic, could someone point me in the right direction ?
As a secondary question, is it possible to redirect the logs in Node-RED's debug console as they currently goes to docker logs (node-RED running as a docker) and finely control what is output ? I don't need the info logs, only warning and errors.
thanks
