Has anyone managed to get color-picker working in a Dashboard Template node?
<color-picker ng-model="myColor" options="{format:'rgb', round:true, hue:false, lightness:false, alpha:false}"></color-picker>
This displays the picker, ng-change doesn't seem to be available for color-picker, so I'm not sure how to get a message out of it.
So apparently this is the color-picker used in Node-RED dashboard. Documentation says;
<color-picker
ng-model="color"
options="options"
api="api"
event-api="eventApi"
></color-picker>
Presumably I need to add an event-api parameter? Here's the documentation for that:
// api event handlers
$scope.eventApi = {
onChange: function(api, color, $event) {},
onBlur: function(api, color, $event) {},
onOpen: function(api, color, $event) {},
onClose: function(api, color, $event) {},
onClear: function(api, color, $event) {},
onReset: function(api, color, $event) {},
onDestroy: function(api, color) {},
I've tried something like this, in the Dashboard Template node (just to see if it sends anything back when I change the colour):
<color-picker ng-model="myColor" event-api="onChange: function() {send({action: 'colchange'})}"></color-picker>
... but it breaks the color-picker element:
Sorry to bump, but can anyone help on this?
Can you live with the html color picker? Not as sexy but often does the job.
<input type="color" ng-model="msg.payload" ng-change="send(msg)">
Thanks, that works for me.
Incidentally, it is pretty sexy on the iphone, as it brings up a nice palette which sends values as you tap around the palette.
But on Chrome in Windows it brings up the old school color selection dialog, which requires clicking on a color then pressing okay (3 clicks).
Is there some cool jquery plugin that could be used to make it marginally nicer?
