Using Environment Variables in settings.js
I am trying to dynamically set my pageTitle.
    "editorTheme": {
        "page": {
            "title": "${BALENA_DEVICE_NAME_AT_INIT}"
I use Balena, and it has an environment variable, that is accessible from within the Node-Red container named BALENA_DEVICE_NAME_AT_INIT.
I tried inserting the environment variable like I have done before in the flows.json, but when its in the settings.js it doesnt seem to work.
Is there a way to use Environment Varaibles within the settings.js?
settings.js is a node.js file so you need to use the node libraries to access the env vars.
How to read environment variables from Node.js (nodejs.dev)
No idea if this will work with Balena, but I use this script to change the editor page header and browser tab title for editor and dashboard. I hope its some use to you.
#! /bin/bash
# Change node-red editor page header to show hostname & IP. Make dashboard browser tab show hostname
DIR=/home/pi/.node-red
# Uses gawk. Probably not needed but a useful catch before running on an unknown system
gawk -V >/dev/null || { echo Please install gawk; exit 1; }
# Does /home/pi/bin/ipaddress exist?
IP=/home/pi/bin/ipaddress
test -x $IP || { echo "This program needs (missing) $IP - quitting." ; exit 1; } # {} groups commands, need ; after last command.
checkfile()
  file=$1; string=$2
  if test ! -f $file
  then
     echo $file not found; return 1
  elif grep $string $file >/dev/null
  then
     echo $string is already in $file - Not changed
     return 1
  fi
echo "=============================================== settings.js ..." # 2 insertions, above module.exports and below editorTheme
FILE=$DIR/settings.js
checkfile $FILE "process.env.HOSTNAME" || exit 1
cp $FILE $FILE.bak || exit 1
gawk ' { if ($0 ~ /^module.exports =/) {
                                          print "// ----------- added by script ----------"
                                          print " hostname = require('\''os'\'').hostname();"
                                          print " const execSync = require('\''child_process'\'').execSync;"
                                          print " const ipaddress = execSync('\''/home/pi/bin/ipaddress'\'', { encoding: '\''utf-8'\'' });"
                                          print " device = hostname + '\'' '\'' + ipaddress;"
                                          print " process.env.HOSTNAME = hostname;"
                                          print " process.env.DEVICE = device;"
                                          print "// --------------------------------------"
                                          print
        else if ($0 ~ /editorTheme: {/) {
                                          print
                                          print "       header: {"
                                          print "          title: process.env.DEVICE"
                                          print "       },"
                                          print "       page: {"
                                          print "       },"
        else print
      }' $FILE > $FILE.tmp
echo $FILE was changed. Original saved as $FILE.bak
echo
mv $FILE.tmp $FILE || exit 1
FLOWFILE=$(grep "^[[:space:]]*flowFile:" $FILE | cut -d "'" -f2)  # flows file may be defined in settings.js
if [ "$FLOWFILE" == "" ]; then FLOWFILE=flows_$HOSTNAME.json ; fi # default value
FILE=$DIR/$FLOWFILE
echo "=============================================== $FLOWFILE ..." # Make dashboard tab on browser = hostname
checkfile $FILE HOSTNAME || exit 1
sed -i s/"Node-RED Dashboard"/'${HOSTNAME}'/ $FILE
if  cmp $FILE $FILE.bak >/dev/null
then
   echo $FILE was not changed.
   rm $FILE.bak
else
fi
echo
echo Finished. Restart node-red to activate changes.
(I think the change in the flows file is only for the dashboard, and I'm not convinced it's working! :upside_down_face: )
Oh - It calls /home/pi/bin/ipaddress:
#! /bin/bash
# Print the eth0 else wlan0 IP address
for IFACE in eth0 wlan0
do
   IP=$(ifconfig $IFACE 2>/dev/null | awk ' /broadcast/ {print  $2 }' )
   if [ "$IP" ]
   then
      echo $IP
      exit 0
   fi
done
On my Pi with HOSTNAME = "Crucial" It changes appearance from this
to this
Thank you guys, I had not even considered changing that header within the page, that is something I will add in as well.
For anyone coming across this in the future, this is what worked for me, that I will expand upon:
My settings.js is very small, only containing the things I need.
setting a var at the top, and then using that within the JSON, the trick to access the ENV variable, as mentioned by someone who replied up above, is process.env.ENVIRONMENTVARIABLENAME
