Hello, in node red tabs only one node will be used and the other node created will remain non-functional. For example, let there be a node named node a in the system, and the other added node a should not be used. what is the way to do this? So I don't want to have n nodes named a. Or let me ask the question this way. How do I know how many nodes have been created?
Could you be clearer ![]()
You can disable a node by going to Manage Palette - once disabled, this node will no longer appear in the left bar.
with counter incremented by RED.nodes.eachNode
Are you developing a node or is this a question related to default nodes? You added the function-node tag.
I think I added the wrong place. Yes, I'm creating a node.
Do you want each node to have a different name?
Why would your users not use the node in the flow?
If you are using a Node as some sort of Configuration, then you need to define a configuration Node.
If a node in the flow is not designed for users to interact with - you really need to be using Config Nodes.
https://nodered.org/docs/creating-nodes/config-nodes
As mentioned by @GogoVega its not really clear what you are trying to achieve.
If you want to know if a node is not being used - Simply don't try and engineer it, its for the user to manage their estate.
