Using subflow environment varibles directly within a http request URL?
Hi
I've been searching for a while, but stay uncertain, all my try's failed so far:
Is there any chance or possibility in a subflow to use an environment variable (defined in the subflow properties button) directly within an URL string, for example in a "http request" node?
As an example, I mean something like this:
URL: https//api.xyz.com/device/{{{here comes my var}}}/settings
or
URL: https//api.xyz.com/device/${here comes my var}/settings
Kind regards
Roman
You can not use env vars as part of a value, it must be the whole value.
A solution is to build the full URL before the http-request node and pass it in as msg.url
