V-card to use width of group
I have a simple-ish page which is set to Grid layout, and 3 groups each set to 6x1. In each group, there is a template node. In each template I used a v-card which I have given a width of 500:
This all looks good on a big screen but as I start to make is smaller the right side of the v-card start disappearing.
I tried to set the width="100%" (I am not every sure if vuetify understand that) but it goes all over the place, and does not seem to align to the contact. Which is unfortunate, as the middle box has actually a few v-card under it.
I also tried setting the page layout to Fixed, but I cannot get 3 groups next to each other.
Do I need all 3 templated to be in a single group? Or any other ideas how to tell v-card to use the full width of the group and not more?
Hmmm, thats odd. Template 100% width is exactly what I would expect you need to do.
Do you have a small reproducable example you can share?
Thanks for pointing about 100%, because I was struggling with same behavior while copy/pasting examples from Vuetify playground.
<template>
  <v-sheet class="mx-auto" width="100%">
    <v-form ref="form">
      <v-container>
works fine for me
I exported the 3 template nodes for you. It will no do much without context data, but will at least render the v-cards.
[{"id":"9d0d7f0104f44d8a","type":"ui-template","z":"dd535f73e60cae86","group":"e0d58841230b2c65","page":"","ui":"","name":"Rule List","order":1,"width":"6","height":"1","head":"","format":"<template>\n  <v-card class=\"mx-auto\" color=\"white\" width=\"450\">\n    <v-img class=\"text-white\" height=\"62\" src=\"https://cdn.vuetifyjs.com/images/backgrounds/vbanner.jpg\"\n      cover>\n\n      <v-toolbar color=\"transparent\">\n        <v-toolbar-title class=\"text-h6\" text=\"Rule List\"></v-toolbar-title>\n                <v-tooltip text=\"Refresh rule list\" location=\"top\">\n                  <template v-slot:activator=\"{ props }\" v-slot:append>\n                    <v-btn v-bind=\"props\" icon=\"mdi-refresh\" @click=\"send({topic: 'refresh', payload: null})\"></v-btn>\n                  </template>\n                </v-tooltip>\n                <v-tooltip text=\"Enabled rule\" location=\"top\">\n                  <template v-slot:activator=\"{ props }\" v-slot:append>\n                    <v-btn v-bind=\"props\" icon=\"mdi-bell-check\" @click=\"send({topic: 'enablerule', payload: null})\"></v-btn>\n                  </template>\n                </v-tooltip>\n                <v-tooltip text=\"Disable rule\" location=\"top\">\n                  <template v-slot:activator=\"{ props }\" v-slot:append>\n                    <v-btn v-bind=\"props\" icon=\"mdi-bell-cancel\" @click=\"send({topic: 'disablerule', payload: null})\"></v-btn>\n                  </template>\n                </v-tooltip>\n                <v-tooltip text=\"Move Up\" location=\"top\">\n                  <template v-slot:activator=\"{ props }\" v-slot:append>\n                    <v-btn v-bind=\"props\" icon=\"mdi-arrow-up-bold-circle-outline\" @click=\"send({topic: 'moveup', payload: null})\"></v-btn>\n                  </template>\n                </v-tooltip>\n                <v-tooltip text=\"Move Down\" location=\"top\">\n                  <template v-slot:activator=\"{ props }\" v-slot:append>\n                    <v-btn v-bind=\"props\" icon=\"mdi-arrow-down-bold-circle-outline\" @click=\"send({topic: 'movedown', payload: null})\">\n                    </v-btn>\n                  </template>\n                </v-tooltip>\n      </v-toolbar>\n      </v-img>\n\n\n\n\n\n\n\n    <v-card-text>\n      <v-list bg-color=\"white\">\n      \n        <v-list-item v-for=\"(item, index) in items\" :key=\"index\" :value=\"index\" :title=\"item.name\" :subtitle=\"item.subtitle\"\n          :prepend-icon=\"getEnabledIcon(item)\" @click=\"send({topic: 'selected', payload: item})\">\n        </v-list-item>\n      </v-list>\n    </v-card-text>\n\n  </v-card>\n</template>\n\n\n\n\n<script>\n  export default {\n        data() {\n            return {\n                counter: 0,\n                items: [],\n                selected: []\n            }\n        },\n        mounted() {\n            this.counter = 0\n        },\n        watch: {\n            msg: function(){            \n                if(this.msg.payload != undefined) {                    \n                    this.items = this.msg.payload;\n                    this.selected = [];\n                    this.counter = this.items.length;     \n                    this.send({payload:undefined});\n                }\n            }\n        },\n        methods: {\n          getEnabledIcon: function (item) {\n            if (item !== undefined ) {\n              if (item.enabled) {\n                return 'mdi-bell-check'\n                  } else {\n                return 'mdi-bell-cancel'\n              }\n            }\n          }\n        }\n    }\n</script>\n\n<style>\n  .v-overlay__content .v-list {\n    background: rgba(var(--v-group-background));\n    color: rgba(var(--v-group-on-background), var(--v-high-emphasis-opacity));\n  }\n</style>","storeOutMessages":true,"passthru":false,"resendOnRefresh":true,"templateScope":"local","className":"","x":500,"y":1200,"wires":[["e0d963d56787736b","17ea1359dbc18a68"]]},{"id":"f20c789a97cb2333","type":"ui-template","z":"dd535f73e60cae86","group":"690c33a99698055d","page":"","ui":"","name":"Rule Details","order":1,"width":"6","height":"1","head":"","format":"<template>\n\n\n<v-card class=\"mx-auto\" color=\"white\" width=\"450\">\n    <v-img class=\"text-white\" height=\"62\" src=\"https://cdn.vuetifyjs.com/images/backgrounds/vbanner.jpg\" cover>\n\n        <v-toolbar color=\"transparent\">\n            <v-toolbar-title class=\"text-h6\" :text=\"rulename\"></v-toolbar-title>\n        </v-toolbar>\n    </v-img>\n\n    <v-card-subtitle>\n        {{ subtitle }}\n    </v-card-subtitle>\n\n    </v-card>\n    <v-card class=\"mx-auto\" color=\"white\" width=\"450\">\n        \n        <v-toolbar color=\"transparent\">\n            <v-toolbar-title class=\"text-h6\" text=\"Conditions\"></v-toolbar-title>\n            <v-tooltip text=\"Move condition up\" location=\"top\">\n                <template v-slot:activator=\"{ props }\">\n                    <v-btn v-bind=\"props\" icon=\"mdi-boom-gate-arrow-up-outline\"\n                        @click=\"send({topic: 'conditionup', payload: null})\"></v-btn>\n                </template>\n            </v-tooltip>\n            <v-tooltip text=\"Move condition down\" location=\"top\">\n                <template v-slot:activator=\"{ props }\">\n                    <v-btn v-bind=\"props\" icon=\"mdi-boom-gate-arrow-down-outline\"\n                        @click=\"send({topic: 'conditiondown', payload: null})\"></v-btn>\n                </template>\n            </v-tooltip>\n            <v-tooltip text=\"Add condition\" location=\"top\">\n                <template v-slot:activator=\"{ props }\">\n                    <v-btn v-bind=\"props\" icon=\"mdi-file-document-plus-outline\"\n                        @click=\"send({topic: 'addcondition', payload: null})\"></v-btn>\n                </template>\n            </v-tooltip>\n            <v-tooltip text=\"Delete condition\" location=\"top\">\n                <template v-slot:activator=\"{ props }\">\n                    <v-btn v-bind=\"props\" icon=\"mdi-delete\"\n                        @click=\"send({topic: 'deletecondition', payload: null})\"></v-btn>\n                </template>\n            </v-tooltip>\n    \n        </v-toolbar>\n        <v-card-text>\n            <v-list bg-color=\"white\">\n                <v-list-item v-for=\"(item, index) in conditions\" :key=\"index\" :value=\"index\" :title=\"item.text\"\n                    :prepend-icon=\"getConditionIcon(item)\" @click=\"send({topic: 'condition', payload: item})\">\n                </v-list-item>\n            </v-list>\n        </v-card-text>\n    </v-card>\n    <v-card class=\"mx-auto\" color=\"white\" width=\"450\">\n        \n        <v-toolbar color=\"transparent\">\n            <v-toolbar-title class=\"text-h6\" text=\"Actions\"></v-toolbar-title>\n            <v-tooltip text=\"Move action up\" location=\"top\">\n                <template v-slot:activator=\"{ props }\">\n                    <v-btn v-bind=\"props\" icon=\"mdi-gesture-swipe-up\" @click=\"send({topic: 'actionup', payload: null})\"></v-btn>\n                </template>\n            </v-tooltip>\n            <v-tooltip text=\"Move action down\" location=\"top\">\n                <template v-slot:activator=\"{ props }\">\n                    <v-btn v-bind=\"props\" icon=\"mdi-gesture-swipe-down\" @click=\"send({topic: 'actiondown', payload: null})\">\n                    </v-btn>\n                </template>\n            </v-tooltip>\n            <v-tooltip text=\"Add SetState Action\" location=\"top\">\n                <template v-slot:activator=\"{ props }\">\n                    <v-btn v-bind=\"props\" icon=\"mdi-book-plus-multiple\" @click=\"send({topic: 'addsetstateaction', payload: null})\">\n                    </v-btn>\n                </template>\n            </v-tooltip>\n            <v-tooltip text=\"Add Control Action\" location=\"top\">\n                <template v-slot:activator=\"{ props }\">\n                    <v-btn v-bind=\"props\" icon=\"mdi-sign-direction-plus\" @click=\"send({topic: 'addcontrolaction', payload: null})\">\n                    </v-btn>\n                </template>\n            </v-tooltip>\n            <v-tooltip text=\"Delete action\" location=\"top\">\n                <template v-slot:activator=\"{ props }\">\n                    <v-btn v-bind=\"props\" icon=\"mdi-delete\" @click=\"send({topic: 'deleteaction', payload: null})\"></v-btn>\n                </template>\n            </v-tooltip>\n        </v-toolbar>\n        <v-card-text>\n            <v-list bg-color=\"white\">\n                <v-list-item v-for=\"(item, index) in actions\" :key=\"index\" :value=\"index\" :title=\"item.text\"\n                    :prepend-icon=\"getActionIcon(item)\" @click=\"send({topic: 'action', payload: item})\">\n                </v-list-item>\n            </v-list>\n        </v-card-text>\n    \n    </v-card>\n</template>\n\n<script>\n    export default {\n        data() {\n            // define variables available component-wide\n            // (in <template> and component functions)\n            return {\n                rulename: \"\",\n                subtitle: \"\",\n                conditions: [],\n                actions: []\n            }\n        },\n        watch: {\n            // watch for any changes of \"count\"\n            msg: function() {\n                if(this.msg.payload != undefined){\n                    this.rulename = this.msg.payload.name;\n                    this.subtitle = this.msg.payload.subtitle;\n                    this.conditions = this.msg.payload.conditions;\n                    this.actions = this.msg.payload.actions;\n                    this.send({payload:undefined});\n                }\n            }\n        },\n        computed: {\n        },\n        methods: {\n            getConditionIcon: function (item) {\n                if (item !== undefined ) {\n                    switch(item.trigger) {\n                        case \"time\":\n                            return \"mdi-clock-time-eight-outline\";\n                            break;\n                        case \"data\":\n                            return \"mdi-matrix\";\n                            break;\n                        case \"state\":\n                            return \"mdi-state-machine\";\n                            break;\n                    }\n                }\n            },\n            getActionIcon: function (item) {\n                if (item !== undefined ) {\n                    switch(item.type) {\n                        case \"control\":\n                            return \"mdi-message-processing\";\n                            break;\n                        case \"setstate\":\n                            return \"mdi-bullhorn\";\n                            break;\n                    }\n                }\n            }\n        },\n        mounted() {\n        },\n        unmounted() {\n        }\n    }\n</script>","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":1130,"y":1200,"wires":[["185ceeaae6edb7c0","e2e3abaaccd62596"]]},{"id":"d859cdcdccc010ab","type":"ui-template","z":"dd535f73e60cae86","group":"504d51af9a92c9a8","page":"","ui":"","name":"All Editors","order":1,"width":"6","height":"1","head":"","format":"<template>\n\n\n<v-card class=\"mx-auto\" color=\"white\" width=\"450\">\n    <v-img class=\"text-white\" height=\"62\" src=\"https://cdn.vuetifyjs.com/images/backgrounds/vbanner.jpg\" cover>\n\n        <v-toolbar color=\"transparent\">\n            <v-toolbar-title class=\"text-h6\" :text=\"title\"></v-toolbar-title>\n            \n        </v-toolbar>\n    </v-img>\n\n    <v-card-text>\n        <div v-html=\"content\"></div>\n    </v-card-text>\n\n    </v-card>\n    <v-card class=\"mx-auto\" color=\"white\" wv-if=\"conditioneditor\" width=\"450\">\n        <v-card-text>\n            <v-combobox label=\"Trigger\" :items=\"['data', 'state', 'time']\" v-model=\"condition.trigger\"></v-combobox>\n            <v-text-field label=\"Operand\" v-model=\"condition.operand\"></v-text-field >\n            <v-combobox label=\"Operator\" :items=\"['LT', 'GT', 'EQ']\" v-model=\"condition.operator\"></v-combobox>\n            <v-text-field label=\"Value\" v-model=\"condition.value\"></v-text-field>\n        </v-card-text>\n        <v-card-actions>\n            <v-spacer></v-spacer>\n            <v-btn color=\"success\" variant=\"flat\" @click=\"send({topic: 'conditionchange', payload: this.condition})\">\n                Update Condition\n                <v-icon icon=\"mdi-chevron-right\" end></v-icon>\n            </v-btn>\n        </v-card-actions>\n    </v-card>\n    <v-card class=\"mx-auto\" color=\"white\" v-if=\"actioncontroleditor\" width=\"450\">\n        <v-card-text>\n            <v-text-field label=\"Type\" model-value=\"Control\" disabled></v-text-field>\n            <v-text-field label=\"Topic\" v-model=\"action.topic\"></v-text-field>\n            <v-text-field label=\"Topic\" v-model=\"action.value\"></v-text-field>\n        </v-card-text>\n        <v-card-actions>\n            <v-spacer></v-spacer>\n            <v-btn color=\"success\" variant=\"flat\" @click=\"send({topic: 'actionchange', payload: this.action})\">\n                Update Action\n                <v-icon icon=\"mdi-chevron-right\" end></v-icon>\n            </v-btn>\n        </v-card-actions>\n    </v-card>\n    <v-card class=\"mx-auto\" color=\"white\" v-if=\"actionsetstateeditor\" width=\"450\">\n        <v-card-text>\n            <v-text-field label=\"Type\" model-value=\"SetState\" disabled></v-text-field>\n            <v-text-field label=\"State\" v-model=\"action.state\"></v-text-field>\n            <v-text-field label=\"Name\" v-model=\"action.name\"></v-text-field>\n            <v-text-field label=\"Value\" v-model=\"action.value\"></v-text-field>\n        </v-card-text>\n        <v-card-actions>\n            <v-spacer></v-spacer>\n            <v-btn color=\"success\" variant=\"flat\" @click=\"send({topic: 'actionchange', payload: this.action})\">\n                Update Action\n                <v-icon icon=\"mdi-chevron-right\" end></v-icon>\n            </v-btn>\n        </v-card-actions>\n    </v-card>\n\n</template>\n\n<script>\n    export default {\n        data() {\n            // define variables available component-wide\n            // (in <template> and component functions)\n            return {\n                title: \"\",\n                conditioneditor: false,\n                actionsetstateeditor: false,\n                actioncontroleditor: false,\n                condition: {},\n                action: {}\n            }\n        },\n        watch: {\n            // watch for any new messages\n            msg: function() {\n                if(this.msg.payload != undefined){\n                    this.title = this.msg.payload.title;\n                    this.conditioneditor = this.msg.payload.conditioneditor ?? false;\n                    this.actionsetstateeditor = this.msg.payload.actionsetstateeditor ?? false;\n                    this.actioncontroleditor = this.msg.payload.actioncontroleditor ?? false;\n                    this.condition = this.msg.payload.condition ?? {};\n                    this.action = this.msg.payload.action ?? {};\n                    this.send({payload:undefined});\n                }\n            }\n        },\n        computed: {\n        },\n        methods: {\n            getConditionIcon: function (item) {\n                if (item !== undefined ) {\n                    switch(item.trigger) {\n                        case \"time\":\n                            return \"mdi-clock-time-eight-outline\";\n                            break;\n                        case \"data\":\n                            return \"mdi-matrix\";\n                            break;\n                        case \"state\":\n                            return \"mdi-state-machine\";\n                            break;\n                    }\n                }\n            },\n            getActionIcon: function (item) {\n                if (item !== undefined ) {\n                    switch(item.type) {\n                        case \"control\":\n                            return \"mdi-message-processing\";\n                            break;\n                        case \"setstate\":\n                            return \"mdi-bullhorn\";\n                            break;\n                    }\n                }\n            }\n        },\n        mounted() {\n        },\n        unmounted() {\n        }\n    }\n</script>","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":1840,"y":1200,"wires":[["23b85808b5d405e2","3e721d5852267663"]]},{"id":"e0d58841230b2c65","type":"ui-group","name":"Rule List","page":"cbbf8c857c4418ed","width":"6","height":"1","order":2,"showTitle":false,"className":"","visible":"true","disabled":"false"},{"id":"690c33a99698055d","type":"ui-group","name":"Rule Details","page":"cbbf8c857c4418ed","width":"6","height":"1","order":3,"showTitle":false,"className":"","visible":"true","disabled":"false"},{"id":"504d51af9a92c9a8","type":"ui-group","name":"Rule Common Editor","page":"cbbf8c857c4418ed","width":"6","height":"1","order":4,"showTitle":false,"className":"","visible":"true","disabled":"false"},{"id":"cbbf8c857c4418ed","type":"ui-page","name":"Rule Editor","ui":"cb79bc4520925e32","path":"/ruleeditor","icon":"gate-nor","layout":"grid","theme":"70c3f16306584459","order":3,"className":"","visible":"true","disabled":"false"},{"id":"cb79bc4520925e32","type":"ui-base","name":"My UI","path":"/dashboard","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control","ui-text"],"showPathInSidebar":false},{"id":"70c3f16306584459","type":"ui-theme","name":"File Browser","colors":{"surface":"#5b56fc","primary":"#0094ce","bgPage":"#ffffff","groupBg":"#ffffff","groupOutline":"#ffffff"},"sizes":{"pagePadding":"0px","groupGap":"0px","groupBorderRadius":"0px","widgetGap":"6px"}}]
At the moment, all the v-cards in the template nodes are set to 450 pixels. Not that some of the templates have multiple cards on under each other.
So ideally I would like the 3 groups/templates to be displayed side-by-side talking up all available screen space.
I don't know if I understood it correctly, but here is my attempt:
Vue uses grid system of 12. Your groups were set for width 6, meaning one will be moved to another row.
I reduced all group widths to 4. And changed to <v-card class="mx-auto" color="white" width="100%">
Thanks a lot, it works great. Somehow I missed this information that Vue is 12 grid wide. Now it all make sense.
Vue isn't - Dashboard (built on Vue) is :smile: - docs
