Verified code for on/off switch
i wish when I put the code "1122" switch is on if I put "1144" the switch will be in off state. But i didn't find the error.
[{"id":"2786ed83.cb4ff2","type":"ui_button","z":"2f0151f5.52bf9e","name":"","group":"4509a4c0.a77afc","order":0,"width":0,"height":0,"label":"Unlock_door","color":"","bgcolor":"","icon":"","payload":"true","payloadType":"bool","topic":"show","x":90,"y":640,"wires":[["66941260.f7d47c"]]},{"id":"8e561e18.3eede","type":"function","z":"2f0151f5.52bf9e","name":"verify_pin","func":"var pins = [\"1122\",\"1144\"];\nvar verified = false;\n\nfor(var i=0;i<pins.length;i++){\n    if(msg.passcode == pins[0]){\n        verified = true;\n        break;\n    }\n    else(msg.passcode == pins[1]){\n        verified = false;\n        break;\n    }\n}\n\nmsg.verified = verified;\n\nreturn msg;","outputs":1,"noerr":0,"x":340,"y":640,"wires":[["82d1fa56.7fe818"]]},{"id":"82d1fa56.7fe818","type":"switch","z":"2f0151f5.52bf9e","name":"check","property":"verified","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"false","repair":false,"outputs":2,"x":470,"y":640,"wires":[["6b2be10c.16e2"],["6b2be10c.16e2"]]},{"id":"6b2be10c.16e2","type":"function","z":"2f0151f5.52bf9e","name":"pin_ok","func":"var msg2 = {};\nmsg2.topic = \"Pin successfully verified To ON!\";\nmsg2.payload = \"\";\n    \nreturn [msg, msg2];","outputs":1,"noerr":0,"x":610,"y":640,"wires":[["37a9f7d8.7d2f98"]]},{"id":"66941260.f7d47c","type":"ui_template","z":"2f0151f5.52bf9e","group":"44c9e6e6.0b4128","name":"Pin_Unlock","order":0,"width":"0","height":"0","format":"<div ng-init=\"init()\" id=\"pin_insert\" class=\"dialog\">\n    \n    <div class=\"dialog_content\">\n        \n        <div class=\"dialog_header\">\n            <span ng-click=\"closeDialog()\" class=\"close\">&times;</span>\n            <h2>Insert PIN</h2>\n        </div>\n        \n        <div class=\"dialog_body\">\n\n           <div layout=\"row\" layout-align=\"center\">\n                <div class=\"number_placeholder\">\n                    {{passcode.substring(0, 1)}}\n                </div>\n                <div class=\"number_placeholder\">\n                    {{passcode.substring(1, 2)}}\n                </div>\n                <div class=\"number_placeholder\">\n                    {{passcode.substring(2, 3)}}\n                </div>\n                <div class=\"number_placeholder\">\n                    {{passcode.substring(3, 4)}}\n                </div>\n            </div>\n            \n            <div layout=\"column\" layout-align=\"center\" style=\"margin-top: 50px\">\n                <div layout=\"row\" layout-align=\"center\">\n                    <div class=\"number_box\">\n                        <md-button class=\"md-raised\" ng-click=\"add(1)\">1</md-button>\n                    </div>\n                    <div class=\"number_box\">\n                        <md-button class=\"md-raised\" ng-click=\"add(2)\">2</md-button>\n                    </div>\n                    <div class=\"number_box\">\n                        <md-button class=\"md-raised\" ng-click=\"add(3)\">3</md-button>\n                    </div>\n                </div>\n                 <div layout=\"row\" layout-align=\"center\">\n                    <div class=\"number_box\">\n                        <md-button class=\"md-raised\" ng-click=\"add(4)\">4</md-button>\n                    </div>\n                    <div class=\"number_box\">\n                        <md-button class=\"md-raised\" ng-click=\"add(5)\">5</md-button>\n                    </div>\n                    <div class=\"number_box\">\n                        <md-button class=\"md-raised\" ng-click=\"add(6)\">6</md-button>\n                    </div>\n                </div>\n                 <div layout=\"row\" layout-align=\"center\">\n                    <div class=\"number_box\">\n                        <md-button class=\"md-raised\" ng-click=\"add(7)\">7</md-button>\n                    </div>\n                    <div class=\"number_box\">\n                        <md-button class=\"md-raised\" ng-click=\"add(8)\">8</md-button>\n                    </div>\n                    <div class=\"number_box\">\n                        <md-button class=\"md-raised\" ng-click=\"add(9)\">9</md-button>\n                    </div>\n                </div>\n                 <div layout=\"row\" layout-align=\"center\">\n                    <div class=\"number_box\">\n                        <md-button class=\"md-raised\" ng-click=\"confirm()\">\n                            <ng-md-icon icon=\"done\" style=\"color:#fff;\"></ng-md-icon>\n                        </md-button>\n                    </div>\n                    <div class=\"number_box\">\n                        <md-button class=\"md-raised\" ng-click=\"add(0)\">0</md-button>\n                    </div>\n                    <div class=\"number_box\">\n                        <md-button class=\"md-raised\" ng-click=\"delete()\">\n                            <ng-md-icon icon=\"arrow_back\" style=\"color:#fff;\"></ng-md-icon>\n                        </md-button>\n                    </div>\n                </div>\n            </div> \n          \n        </div> <!--dialog_body-->\n    </div> <!--dialog_content-->\n</div>  <!--dialog-->\n\n\n<style>\n\n/* The Dialog (background) */\n.dialog {\n    display: none; /* Hidden by default */\n    position: fixed; /* Stay in place */\n    z-index: 9999; /* Sit on top */\n    left: 0;\n    top: 0;\n    width: 100%; /* Full width */\n    height: 100%; /* Full height */\n    overflow: auto; /* Enable scroll if needed */\n    background-color: rgb(0,0,0); /* Fallback color */\n    background-color: rgba(0,0,0,0.4); /* Black w/ opacity */\n    -webkit-transform: translateZ(0px);\n    -webkit-transform: translate3d(0,0,0);\n    -webkit-perspective: 1000;\n}\n\n.dialog_content {\n    position: absolute;\n    background-color: #fff;\n    margin-top: 9%;\n    margin-left: 7%;\n    padding: 0;\n    width: 300px;\n    box-shadow: 0 4px 8px 0 rgba(0,0,0,0.2),0 6px 20px 0 rgba(0,0,0,0.19);\n    -webkit-animation-name: animatetop;\n    animation-name: animatetop;\n    animation-duration: 0.4s;\n}\n\n/* Media query for smartphones (to Fix?) */\n@media only screen and (min-device-width : 375px) and (max-device-width : 667px) { \n    .dialog_content {\n    margin-top: 5%;\n    margin-left: 5%;\n}\n}\n\n/* Add Animation */\n@-webkit-keyframes animatetop {\n    from {top: -300px; opacity: 0} \n    to {top: 0; opacity: 1}\n}\n\n@keyframes animatetop {\n    from {top: -300px; opacity: 0}\n    to {top: 0; opacity: 1}\n}\n\n/* Dialog Header */\n.dialog_header {\n    padding: 2px 16px;\n    background-color: #03A9F4;\n    color: white;\n}\n\n/* Dialog Body */\n.dialog_body {padding: 16px 16px;}\n\n/* The Close Button */\n.close {\n    color: #fff;\n    float: right;\n    font-size: 28px;\n    font-weight: bold;\n}\n\n.close:hover,\n.close:focus {\n    color: #1565C0;\n    text-decoration: none;\n    cursor: pointer;\n}\n\n/* __ */\n.number_placeholder{\n    width: 50px;\n    height: 34px;\n    margin: 10px;\n    font-size: 20pt;\n    text-align: center;\n    border-bottom: 1px solid black;\n}\n\n/* Number container */\n.number_box{\n    margin: 10px;\n}\n\n/* Buttons style */\n.md-button.md-default-theme.md-raised, .md-button.md-raised{\n    min-height: 50px;\n    min-width: 50px;\n    font-weight: bold;\n    margin: 0px 10px 10px 0px;\n    box-shadow: 4px 4px 6px 0 #dadada;\n    background-color: #29B6F6;\n    color: #fff;\n}\n\n.md-button.md-default-theme.md-raised:not([disabled]):hover, .md-button.md-raised:not([disabled]):hover{\n    background-color: #03A9F4;\n}\n\n.btn1 {\n  color : rgb(49, 46, 46);\n  background-color: rgba(255, 222, 121, 0.96);\n  border-radius: 10px 0 0 10px;\n  font-size: 16px;\n}\n\n.btn1:not([disabled]):hover {\n  background-color: rgba(107, 103, 91, 0.96);\n  color: white;\n}\n\n.btn1[disabled] {\n  color : rgb(187, 187, 187);\n  background-color: rgba(230, 230, 229, 0.96);\n}\n\n</style>\n\n<script>\n\n/**\n * pin_dialog.js\n * Node-Red UI template for Node-Red Dashboard. \n * Custom dialog that asks for a PIN to allow actions\n * Enjoy it :). \n * -- Daniel\n *\n *\n * @license The Unlicense, http://unlicense.org/\n * @version 0.1\n * @author  Daniel Lando, https://github.com/robertsLando\n * @updated 2017-03-08\n * @link    ----\n *\n *\n */\n\nvar dialog;\n\n/* ==== */\n(function(scope) {\n    \n    scope.passcode = \"\";\n    scope.payload = \"\";\n    scope.inited = false;\n    \n    scope.init = function() {\n        scope.passcode = \"\";\n        //Hide the md-panel\n        $('#pin_insert').parent().parent().css(\"display\", \"none\");\n        //This trick make it works on smartphones too :)\n        dialog = $('#pin_insert').detach();\n        dialog.appendTo(document.body);\n    }\n    \n    scope.showDialog = function() {\n        dialog.css(\"display\", \"block\");\n    }\n    \n    scope.closeDialog = function(){\n        dialog.css(\"display\", \"none\");\n    }\n    \n    scope.add = function(value) {\n        if(scope.passcode.length < 4) {\n            scope.passcode = scope.passcode + value;\n            if(scope.passcode.length == 4) {\n                console.log(\"The four digit code was entered\");\n                   \n            }\n        }\n    }\n \n    scope.delete = function() {\n        if(scope.passcode.length > 0) {\n            scope.passcode = scope.passcode.substring(0, scope.passcode.length - 1);\n        }\n    }\n    \n    scope.confirm = function() {\n        if(scope.passcode.length == 4) {\n            scope.send({passcode: scope.passcode, payload : scope.payload});\n            scope.closeDialog();\n            scope.passcode = \"\";\n            scope.payload = \"\";\n        }\n    }\n\n    scope.$watch('msg', function(data) {\n        if(data && data.topic){\n            switch(data.topic){\n               case \"show\":\n                   if(scope.inited){\n                        scope.payload = data.payload;\n                        scope.showDialog();\n                   }\n                   else\n                        scope.inited = true;\n                break;\n                case \"close\": \n                    scope.closeDialog(); \n                break;\n            }\n        }\n    });\n})(scope);\n\n</script>\n","storeOutMessages":false,"fwdInMessages":false,"templateScope":"local","x":211,"y":580,"wires":[["8e561e18.3eede"]]},{"id":"37a9f7d8.7d2f98","type":"switch","z":"2f0151f5.52bf9e","name":"","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":730,"y":640,"wires":[["396c9ceb.4354e4"],["396c9ceb.4354e4"]]},{"id":"396c9ceb.4354e4","type":"ui_switch","z":"2f0151f5.52bf9e","name":"","label":"door PIN","tooltip":"","group":"3549a6e5.8b361a","order":9,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":880,"y":640,"wires":[[]]},{"id":"4509a4c0.a77afc","type":"ui_group","z":"","name":"Secure","tab":"a2361348.4a6dc","disp":true,"width":"6"},{"id":"44c9e6e6.0b4128","type":"ui_group","z":"","name":"pin","tab":"a2361348.4a6dc","disp":false,"width":"5","collapse":false},{"id":"3549a6e5.8b361a","type":"ui_group","z":"","name":"Demo","tab":"23ec798a.3b8f36","disp":true,"width":"8","collapse":false},{"id":"a2361348.4a6dc","type":"ui_tab","z":"","name":"Home","icon":"home","order":12,"disabled":false,"hidden":false},{"id":"23ec798a.3b8f36","type":"ui_tab","z":"","name":"Home","icon":"dashboard","order":13,"disabled":false,"hidden":false}]
Where are all your debug nodes so you can see what actual messages you are passing? This will help you locate the error by seeing where the logic diverts from what you want
for two operation when i put the code i get true for all nodes
Hi.
I am not getting what you are wanting to do.
Looking at the picture of the flow, there is a button, then the Pin_unlock node, a verify_pin, check and so on.
These go (ultimately) to the door PIN node which is a node to show you the state.
(Got that bit)
But where is the pin entered?
If it is that it sends 1122 or 1144 alternatively with each button press, then I am not getting why you need the pin in the scenario.
Yeah, ok, I should maybe look at the flow, but I am just passing by and read the post.
Then I saw the flow and what you say.
As I said, I am not getting what it is you want to do because what I am seeing isn't what you are writing/asking.
I don't want to sound dismissive. I am new at this too. Though I guess I have got a bit of practise with using NR.
Hope to hear back.
so check what messages you are sending (using a debug node) and then
read the docs section on how to log events within a function.
https://nodered.org/docs/writing-functions#logging-events
@hebergeweb You should go read the info tab of the swtch node to understand what it does.
in the template(Pin_Unlock) there is an interface of the buttons (numbers[1,2,3,4...]) where I put the code "1122" to open the door (ui_switch changed to on) and the code "1144" to close the door (ui_switch changed to off).
to open it works well but to close it I have no answer the switch remains in state on.
  1. you have a bug in your fundtion node
  2. you need to go read up on the switch node Edit: actually strike that, instead tell us what you think the switch node does.
