I want to plot a line chart of vibration sensor Data. Following is my flow. How can i plot a real time line chat using node red where x-axis will be frequency and y-axis will be amplitude.
[{"id":"5c0f3e4b.7b304","type":"tab","label":"Vibration_Dashboard","disabled":false,"info":""},{"id":"b6aa9d6f.49572","type":"debug","z":"5c0f3e4b.7b304","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":590,"y":340,"wires":},{"id":"99cd2832.db55f8","type":"inject","z":"5c0f3e4b.7b304","name":"","props":[{"p":"payload"},{"p":"object","v":"","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{'x':'23','y':4}]","payloadType":"str","x":90,"y":260,"wires":[["259e195b.bcdd76"]]},{"id":"d8f752e4.11982","type":"function","z":"5c0f3e4b.7b304","name":"","func":"var msg1={}\nvar msg2={}\nvar buffer=msg.payload.split(",");\nmsg1.payload=parseInt(buffer[0]);\nmsg2.payload=parseInt(buffer[1]);\n\n\nconst dTrig = (trigFunc, angle) => trigFunc(angle * Math.PI / 180);\nvar values= ;\n\nfor(let i=0; i<values.length; i++){\n values[i] = parseInt(buffer[0]);\n //dTrig(Math.sin, i*360/values.length);\n}\n\nmsg.payload={\n data: values\n };\n \nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":420,"y":60,"wires":[["b6aa9d6f.49572","7fa64770.c07018"]]},{"id":"259e195b.bcdd76","type":"change","z":"5c0f3e4b.7b304","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"[","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"]","fromt":"str","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":280,"y":200,"wires":[["e567e5f8.0a5048"]]},{"id":"e567e5f8.0a5048","type":"change","z":"5c0f3e4b.7b304","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"{","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"}","fromt":"str","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":280,"y":240,"wires":[["893f85f1.204518"]]},{"id":"893f85f1.204518","type":"change","z":"5c0f3e4b.7b304","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"'x'","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":":","fromt":"str","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":280,"y":280,"wires":[["d9406f80.3dc26"]]},{"id":"d9406f80.3dc26","type":"change","z":"5c0f3e4b.7b304","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"'y'","fromt":"str","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":300,"y":320,"wires":[["8c742b93.9e3798"]]},{"id":"8c742b93.9e3798","type":"change","z":"5c0f3e4b.7b304","name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"'","fromt":"str","to":"","tot":"str"},{"t":"change","p":"payload","pt":"msg","from":"'","fromt":"str","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":300,"y":380,"wires":[["d8f752e4.11982"]]},{"id":"7fa64770.c07018","type":"ui_template","z":"5c0f3e4b.7b304","group":"95c16e78.88cee","name":"HiChart","order":0,"width":0,"height":0,"format":"\n\n<script src="https://code.highcharts.com/highcharts.src.js">\n\n\n<div id="graph" style="min-width: 600px; height: 300px; margin: 0 auto">\n\n\n\n","storeOutMessages":false,"fwdInMessages":false,"resendOnRefresh":false,"templateScope":"local","x":640,"y":180,"wires":[]},{"id":"95c16e78.88cee","type":"ui_group","name":"Group 1","tab":"e1f4390.2c4a7c8","order":1,"disp":true,"width":6},{"id":"e1f4390.2c4a7c8","type":"ui_tab","name":"Home","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
